I got oof shearer right now. Would i get more from inframe snipers? Im dragging on 300ft sand.
heres a copy of the GAS dyno sheet 421 Cub Sniper inframe vs. Shearer OOF drag pipe
It is based on ground speed instead of RPM...its all I have on hand at the moment .Dyno operator killed the test early after peak HP....both pipes have better over-rev than what the chart would indicate
Post RPM on bottom of dyno runs....otherwise people are going to ask why this motor is only capable of running to 70 MPH, then falls on it's face. :shootself:
Yea, I know, thats why I gave the footnote..Its all I had on hand...but the HP and Tq. speak for itself
  • Like 1
Hey Jim is that similar to what this motor you ported for me should be?
Your torque numbers should be a little higher than this engine...peak hp should nearly the same.
  • 10 months later...
