shakenbake1285 Posted May 19, 2010 Report Share Posted May 19, 2010 1500 ft above sea level, toomey t6 exhaust, uni air filter and the tors r removed. Right now my bike will not idle and the bottom end has some miss in it n backfire is that because of stock jets n needles Quote Link to comment Share on other sites More sharing options...
shakenbake1285 Posted May 19, 2010 Author Report Share Posted May 19, 2010 And also who makes best jetkit and fastest place to get them delievered Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted May 19, 2010 Report Share Posted May 19, 2010 Didn't your T6s come with a jet kit? I thought all Toomey pipes came with a Toomey jet kit. Did whoever you got the pipes from not supply it? Quote Link to comment Share on other sites More sharing options...
shakenbake1285 Posted May 19, 2010 Author Report Share Posted May 19, 2010 I got the pipes off a buddy he has jets n stuff on his bike Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted May 19, 2010 Report Share Posted May 19, 2010 Ask your buddy what jets came with the pipes, and go buy them, along with several sizes larger, and smaller. The jet kits are overpriced, and don't always have the sizes you need. Quote Link to comment Share on other sites More sharing options...
shakar Posted May 19, 2010 Report Share Posted May 19, 2010 if u got stockers theres a dude on ebay that has a decent kit for like 30 shipped Quote Link to comment Share on other sites More sharing options...
shakenbake1285 Posted May 19, 2010 Author Report Share Posted May 19, 2010 Yea I got all stock carbs. The bike will idle if I choke it. Is that from not being jetted (I tried the idle screws with no luck) Quote Link to comment Share on other sites More sharing options...
shakar Posted May 20, 2010 Report Share Posted May 20, 2010 (edited) http://www.toomey.com/ and go to documents then t=6 instalation /jeting directions ......... might help?? Edited May 20, 2010 by shakar Quote Link to comment Share on other sites More sharing options...
SNTBANSHEE Posted May 20, 2010 Report Share Posted May 20, 2010 Yea I got all stock carbs. The bike will idle if I choke it. Is that from not being jetted (I tried the idle screws with no luck) Yeah ,when you pull the choke you are making the mix richer which means you are lean right now. You need to jet up. Check the pipe manufacturer's jetting recommendations and go from there. Quote Link to comment Share on other sites More sharing options...
shakenbake1285 Posted May 20, 2010 Author Report Share Posted May 20, 2010 Thanks Quote Link to comment Share on other sites More sharing options...
shakenbake1285 Posted May 20, 2010 Author Report Share Posted May 20, 2010 Do I have to buy new jets or can I adjust the stock ones n make them work ( if so what do I need to do) Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted May 20, 2010 Report Share Posted May 20, 2010 You have to buy the needed jets. There's no adjustments on the jets, only the idle screws, and the air mixture screws. Quote Link to comment Share on other sites More sharing options...
