What jet kit setup do I need
Yea I got all stock carbs. The bike will idle if I choke it. Is that from not being jetted (I tried the idle screws with no luck)
Yeah ,when you pull the choke you are making the mix richer which means you are lean right now. You need to jet up. Check the pipe manufacturer's jetting recommendations and go from there.
