jack350 Posted May 15, 2010 Report Share Posted May 15, 2010 hey guys i know ur prob sick of this topic but im in a bit of pickle.... ok so i want my next mod to be a coolhead.. there are a couple of different ones (as u all know) Noss head, pro design and chariot..etc i have seen the noss head and think i want it (anodized black).. but i would like to know the pro's and con's of all of them... and i have heard the chariot one is very installer friendly (correct me if im wrong).. in conclusion i wanna know which size domes and which one is the best for cooling, installing and maintain.. i also wanna stay on pump gas and im from downunder so our 98 octane is ur 93 octane. my mods inc: stock motor t-5 pipes VF3 pro design foam filter +4 timing TORS elim 2000ft above sea lv toomey jet and needle 280 main stock pilots 120 psi 115 psi compression please help me guys thanks jack Quote Link to comment Share on other sites More sharing options...
makemefaster Posted May 15, 2010 Report Share Posted May 15, 2010 really all the heads are about the same you just have to be careful when putting the o rings on.A guy gave me a tip on how to install them i have never had a problem since .If you put a little Vaseline on the o rings then they will stay in the parts and not fall when you are installing them.Also put the dome on the cyl centered and then the base then the stud o rings then the top plate and you shouldn't have any problems just remember to recheck you torque after about a hour of run time. Quote Link to comment Share on other sites More sharing options...
06specialedition Posted May 15, 2010 Report Share Posted May 15, 2010 I couldn'y be happier with my Wildcard Racing Noss Head.....I looked at cool heads for awhile and I'm glad a when with Noss. Quote Link to comment Share on other sites More sharing options...
tonyown Posted May 15, 2010 Report Share Posted May 15, 2010 Noss are great cool head never had any problem install it and never leaked.... like it! my blue anodized looks pretty good after years of use. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted May 15, 2010 Report Share Posted May 15, 2010 Yea get one from Noss Machine. Dave is a super nice guy. The 2 pice designe is nice for installation. You can set a dome on each cylinder then slide the shell over the studs and visually see that they are lined up right. josh Quote Link to comment Share on other sites More sharing options...
firebanshee Posted May 16, 2010 Report Share Posted May 16, 2010 I think the pro design cool heads suck.You have to get different studs,which mean you could pull the threads out of your cylinder when chanfing them and they don't have the proper coolant flow.They allow the coolant to just shoot across the top of the domes instead of making it go down into the cylinders and up and across.The NOSS is a good cool head, You would need a 21cc dome to run pump gas at sea level. Quote Link to comment Share on other sites More sharing options...
jack350 Posted May 16, 2010 Author Report Share Posted May 16, 2010 (edited) ok thanks guys NOSS head it is.. Edited May 16, 2010 by jack350 Quote Link to comment Share on other sites More sharing options...
alf44 Posted May 16, 2010 Report Share Posted May 16, 2010 PM SENT Quote Link to comment Share on other sites More sharing options...
dlnoss Posted May 17, 2010 Report Share Posted May 17, 2010 Hey Alf, you aren't trying to steal a sale with a last-second PM are you? j/k Quote Link to comment Share on other sites More sharing options...
camatv Posted May 17, 2010 Report Share Posted May 17, 2010 i really enjoy my NOSS head and have refered a bunch of peeps to him ( thoo i have never talked to dave directelly) but will in the future as he's cutting domes for a guy that i use for domes.. the pro desing heads i have all came with the bikes i bought and they are ok. i really prefer NOT having to remove the studs if you read the directions that come with the heads they all say to use grease/ vaseline to install the o-rings makes it very easy.. Quote Link to comment Share on other sites More sharing options...
jack350 Posted May 18, 2010 Author Report Share Posted May 18, 2010 hey guys thx for all ur inputs.. My Black NOSS head n 21cc domes is on thee way home cant wait!!! one more thing does any1 no for sure does the NOSS head if bought directly from dave come with chrome acorn nuts or what?.. just so i can organise some from fast or who ever if not.. thx again Quote Link to comment Share on other sites More sharing options...
