Wack Jetting
ok guys heres the mods, pro mx ported and polished by trinity, cool head 20cc domes, bored 80 over weisco pistons, 28mm pwks ptr mid revs, stock air box with k&n +4 timing 500 feet above see level 60-90 degrees temp 155 mains not sure on needle height needle says 3.5 for size not sure on pilot it rans awesome but since i jetted it to 155 it just dont pull as hard same when i advanced the timing any advice would help please dont make jokes i listed everything i know just trying to get help form good guys that know there stuff thanks.
cananyone help me? thought people would give advice. please and thank you.
what octane gas you running with 20cc domes? and whats your compression?
Timing plate or key? If key maybe you put it in backwards. Why did you change jets?What were jets you took out ?Did you change anything else at the same time ? Try it with jets you took out.
its a timing plate, i jetted it because it was sputtering out one carb bad. when i jetted it it came alive then when i did the timing it just dont pull the same i smoked my buddys yfz like nothing an now it stays with or passes me so i got something wrong..lol im runnin 93 oct. not sure on compression yet, i jetted it down to 150 main an it does a little better but that shouldnt be right should it i should have to jet up?
does it revs easy but doesn't pull that hard ? if so probably lean ... also make sure you didn't -4 your timing (sometimes we do some dumb shit without being dumb lol)
Also .. does it pull ok from 0 to 1/2 throttle (like before) ?
Chris
timing is right..lol but shit does happen, ya it still gos good up to half way throttle response is awesome.
