Valin Posted May 9, 2010 Report Share Posted May 9, 2010 I am selling a Memphis 16-MCA3004 4 channel amplifier. It retailed at $555. I'll take $200 + shipping, or trade for: -Trail Tech lights in great shape -billet intakes for 33-35mm carbs -Racetech rear shock valve kit, or aftermarket rear shock set up for +4 swinger -new FAST clutch kit or equivalent to support a 421 cub -lockup and cover -Billet intakes for 33-35mm carbs -aftermarket stator cover - ??? It is in perfect working condition, and has a few slight scratches on the surface. I'd rate it an 8 out of 10 for cosmetic, and 10 out of 10 for performance. Here is a picture of it when I was installing it. It is the amplifier on the right. Specs: # 4-Channel MClass Series Amplifier # Compact Aluminum Chassis with Custon Black Pearl Finish # Gold Plated RCA Connectors # Full MOSFET Design # Fully Variable Crossover: HP/LP (40 Hz - 6 kHz) # 4-Way Protection Circuitry # Platinum Finish Wire Connections # Accepts 4 Gauge Power and Ground Wire # Optional Wired Remote Gain Control # RMS Power Ratings: * 75 watts x 4 chan. @ 4 ohms * 115 watts x 4 chan. @ 2 ohms # Adjustable Input Sensitivity: 250mV - 5V # Dimensions: 18.5" L x 7.6" W x 2.4" H Quote Link to comment Share on other sites More sharing options...
Valin Posted May 17, 2010 Author Report Share Posted May 17, 2010 Now on eBay. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290436338762&ssPageName=STRK:MESELX:IT Quote Link to comment Share on other sites More sharing options...
