Fastassbanshee96 Posted May 8, 2010 Report Share Posted May 8, 2010 I have a set of haulers and one of the paddles started to lift from the tire. It's not too bad but am wondering if there is anything out there to glue it back in place or something. I know it probably won't hold for long but would just like to get atleast another season out of them. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 8, 2010 Report Share Posted May 8, 2010 Don't know if there are any tire recappers still in this area, might check with one of them. Used to be one in Rochester. Quote Link to comment Share on other sites More sharing options...
Fastassbanshee96 Posted May 8, 2010 Author Report Share Posted May 8, 2010 Don't know if there are any tire recappers still in this area, might check with one of them. Used to be one in Rochester. So you don't know of any glue or anything I can use as a quick fix on it. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted May 9, 2010 Report Share Posted May 9, 2010 i really don't think your std. vulcanizing compound will hold a paddle down, and i know cyanoacrylate (super glue/plane-hobby glue) will hold a butt joint on an o-ring, but tire cappers use an adhesive to glue the new tread on old tires, and that will hold permenantly. you may get away with window weld- windsheild eurothane, which is some pretty strong stuff, but anything else you use as a temp fix might keep it from being repaired the right way later. Quote Link to comment Share on other sites More sharing options...
