spark arrestors
Free word of advice here...YOU CANNOT JUST PUT SCREEN IN YOUR PIPES AND GET AWAY WITH IT AT SILVER LAKE. The DNR guys and gals don't know much....but they DO KNOW what silencers came with spark arrestors. They even have laptops at the gates with ALL the pipes that ever came with arrestors in a picture file! :unsure: I've seen them use it to double check a dirtbike rider who was trying to sneak thru with the screen trick! :( FMF TURBINE CORES are your best bet for a 2-stroke with a typical pipe set-up...otherwise you'll need the Cobra Sparky's. When in doubt they look for the USFS stamping. Buy them before you get there.....DAR "Dune Land" charges a fortune for them cause they know you have no other choice. Clean them every 10 ride hours like the directions say...or you'll see power drop even more. Also watch that your fiberglass silencer material doesn't get all blocked up in them. You can pull them off once your in...but you risk a fine.
If your riding a 4 stroke...leave your spark arrestors in your pipe....your not going to be fast even with them out. :lol:
banghead I wish "Big Brother" could adjust that rule for Silver Lake....I've never seen a sand fire before. :shrugani: But the rule was written to cover the Trail system. They just won't change the enforcement because it also helps lower your sound levels which they have problems with thanks to a lawsuit.
Hope that helps ya' :D
