GrMeyer Posted May 23, 2010 Report Share Posted May 23, 2010 I say buy some arms made for the banshee and add the yfz shocks to them. That is what I have done and has worked out great. Just need to change them into dual rate spings and revalve them for the dunes. just my .02 Quote Link to comment Share on other sites More sharing options...
smokin 421 Posted June 4, 2010 Report Share Posted June 4, 2010 they will work on the stock a-arms you need to grind on the upper shock mounts for clearance and the best way to do the arms is to cut as close to the shock mount as you can get and then take a long extension and dent it in to clear the bottom of the shock... i like this better than grinding my shocks as i find the arms are worth much less. its worked great and have done it to both of our banshees and we ride and jump constantly. fyi yfz shocks with a step on the bottom of the ressy are both hi and lo compression adjustable. Quote Link to comment Share on other sites More sharing options...
sanddragon2004 Posted June 16, 2010 Report Share Posted June 16, 2010 Fireball racing makes an arm for the banshee specifically engineered to work with the yfz shock. I think they are like 399.99 for a set. and you can reuse your spindles and front end simply just changing the shocks. Quote Link to comment Share on other sites More sharing options...
