Bri894 Posted May 2, 2010 Report Share Posted May 2, 2010 What do you guys who have Fullbore or Maier plastics do about your radiator cap. Is ther somewhere I could get a billet/polished one or a cover for the stock one? Thanks Brian Quote Link to comment Share on other sites More sharing options...
TNTS355 Posted May 2, 2010 Report Share Posted May 2, 2010 Check this one out. It has a temp gauge on the top. If I buy a fullbore I will pic one up. http://www.summitracing.com/parts/MRG-2473S/All/ Quote Link to comment Share on other sites More sharing options...
alf44 Posted May 2, 2010 Report Share Posted May 2, 2010 I can also get you billet caps. some with designs. Hit me up anytime. Quote Link to comment Share on other sites More sharing options...
Bri894 Posted May 2, 2010 Author Report Share Posted May 2, 2010 I can also get you billet caps. some with designs. Hit me up anytime. I will hit you up. You already got me some stuff for my Banshee & YFZ. Bri Quote Link to comment Share on other sites More sharing options...
DiSkOe*1 Posted May 3, 2010 Report Share Posted May 3, 2010 Check this one out. It has a temp gauge on the top. If I buy a fullbore I will pic one up. http://www.summitracing.com/parts/MRG-2473S/All/ holds to much psi... will blow a gasket to blow of pressure... stock cap is 1.1psi... id buy that one tho if it was stock psi... DiSkOe*1 Quote Link to comment Share on other sites More sharing options...
chunky77 Posted May 4, 2010 Report Share Posted May 4, 2010 I can also get you billet caps. some with designs. Hit me up anytime. how much for the billet radiator cap? is it polished or unfinished? thanks Quote Link to comment Share on other sites More sharing options...
lilmegill727 Posted May 5, 2010 Report Share Posted May 5, 2010 holds to much psi... will blow a gasket to blow of pressure... stock cap is 1.1psi... id buy that one tho if it was stock psi... DiSkOe*1 found this http://www.thumpertalk.com/forum/thread/550343/radiator-cap-solution Quote Link to comment Share on other sites More sharing options...
