carb settings? help
2003, paul turner mid range pipes, fmf turbine core silencers, +4 degrees timing, sars removed, stock bore, k& n filter in box with lid removed. ok is this right on the carbs? stock pilot, 290 main, second notch down from top on stock needles. 2 and a half turns out on air fuel mixture. thanks guys, just got it
what elevation r u at?........look at jetting forum and find similar shee and elevation---------http://bansheehq.com/forums/index.php?showtopic=99361n :cheers:
have you just bought the bike and this is the jetting it has, or have you been playing and this feels like the best jetting ?
290-310 is about the range, 2 1/2 turns sound excessive, whats it like at 2 turns ?, 2nd notch down from the top is leaning the needle, i dont know what the bike feels like so i cant answer the needle clip position.
some people dont do plug chops, some do, but if your not shaw, a plug chop can be a good indication to see where you are at on your main jet.
im happy you dont have sars anymore, but tors can be a problem.
at 2 turns it is boggy at take off, from idle till it reaches mid range then goes like heck. plug chop... no where to do it around here. 2 and a half turns on the a/f mix seems alot better, but i dont want to burn up a piston. i just bought it a week ago. just thought i would get some imput on here.
i gave my banshee a shot for the sars and it went away, im a dumbass ,,yes the tors is removed. lol
