Badbar88 Posted April 30, 2010 Report Share Posted April 30, 2010 I ride at Glamis mostly and when I run up Olds hill I run to the top in third gear. Once in a great while,on a good run, whoops aren't to deep, I can hit fourth and pull it to the top. Do you guys think I could get fourth more often with a gear change? I'm running stock gearing currently. If so what size would I go with? Quote Link to comment Share on other sites More sharing options...
militarybanshee Posted April 30, 2010 Report Share Posted April 30, 2010 (edited) I ride at Glamis mostly and when I run up Olds hill I run to the top in third gear. Once in a great while,on a good run, whoops aren't to deep, I can hit fourth and pull it to the top. Do you guys think I could get fourth more often with a gear change? I'm running stock gearing currently. If so what size would I go with? drop 1 tooth in the front, you should hit powerband mid range of 4th gear on olds.. and if you are running stock now, drop 1 in the front, its cheaper then adding 3 teeth to the rear Edited April 30, 2010 by militarybanshee Quote Link to comment Share on other sites More sharing options...
Badbar88 Posted April 30, 2010 Author Report Share Posted April 30, 2010 That's exactly what I was hoping to hear man, thanks for the info. Quote Link to comment Share on other sites More sharing options...
Belal4242 Posted May 1, 2010 Report Share Posted May 1, 2010 (edited) Military's 100% right. I do most of my Banshee riding in Glamis with about the same mods as you. I dropped a tooth up front and I do every dune out there in 4th. China, Olds, etc. 5th gear sometimes on a REALLY good run if the whoops aren't too bad. 11 year old all stock suspension so whoops kinda kick my butt lol. Edited May 1, 2010 by Belal4242 Quote Link to comment Share on other sites More sharing options...
