Need Help
I pulled my head off to take a look after the break in and found something unusual to me anyway. Also I had a plug back out on me but I know I didnt have it very tight to begin with. Maybe a quater turn after touching the washer . It was new also.First here is a pic of my domes and they look like oil and water mixed.
I wiped some off
i am running caster 927 at 32:1
I chechecked tha rad before taking head off and it was full
Number 2
The right plug backed out and it looks like some very light pitting on the dome
left cyl
Here are both cyl
Give me some help guys
If i run with the plug loose is that enough to cause deto?
Edited by robert0762
I know on brand new plugs you got to crush the washer down on them,hell from seated I can get almost a full turn out of them.
Do a google search on piston wash and read up on it, the way your pistons look your pretty darn close to where you need to be.
Your running premium pump gas(91 oct or better)right?
Do a compression check to see where your at.
I think o rings are bad
they dont look good it looks like the one got pinched by the flat of the head and cyl
check you head and cylinders with a straitedge to make sure they are flat not warped
Edited by toytech
Come on fellas need some feed back
K, as I understand it, you have +4 timing, stock cyl, MX port, 91 oct? What is the squish clearance and how are the domes calculated? Ie, usually guys are offering the corrected number so if your dome displaces 26cc and you have say 7cc of piston sticking out of the hole, you have a 19cc dome. Squish and comp are good things to look at, at this point.
B
B
Hjr set up the domes to run pump fuel
He said they are a 23 cc flat volume
Waiting on new o rings to check squish
Guess i gotta go buy a comp tester dont have one
I am thinking some numbers are off here. 23cc measured volume - (approx) 6.6cc for piston = 16.4cc trapped. That would be enough to blow some shit in record time. Yeah, I would say testing that comp will be a good start.
You do not need Orings to test the squish. Just shell it without the rings. They do not contribute dimensionally.
23cc trapped should be just fine all day long. Why don't you get Kev in on this? I am not sure you even have an issue. It looks like you might have just pinched an oring.
Brandon
Brandon
must be corrected then cause i put 91 octane in it and she ran great till the plug popped out.
I cant remember ever taking a head off and having that much oil sitting on it. Is this typical of caster. Is there a poss jetting issue? Is it because some water seeped in?
You are probably all loaded up and you are getting non-atomized fuel up in the head. Yes, caster coats things very well. Expect to see things a little gummier. I am betting you are fine. oring it and run it. A good idea to test comp and squish though. If you give the exhaust port height, that will help determine if your comp is where it should be.
B
B
I will take a port height measurment and check squish 2 morrow. If you could check back in on me that would be great
