Suspension questions
Techhnyne
i need to replace my a arms on my banshee but instead of going stock i wanna go aftermarket.
now i know there is +2+1 arms and race arms.
what is extended suspension travel mean and what is it compared to a arm set ups that are not long travel arms?
i wanna know before i make a choice and purchase a arms
the increase in width adds stability to the bike. going +1 forward helps to keep the front end down a little more because it pts the weight of the tires a little further forward.
if you go with a set of +2 arms, you will want to consider an aftermarket shock or even a set of YFZ450 shocks. the stock length shocks will be too soft and spongy for the additional arm length.
a long travel setup is a longer arm that uses a very long shock to achieve more travel. those setups are generally pretty expensive and the regular rider will not notice the difference in ride between a regular arm setup and a long travel setup.
what kind of money are you wanting to spend and i can help put you in the best possible direction?
i disagree loco, long travel rocks. yes there expensive and not many people manufacture them. the banshees chassis really limits the suspension travel and the handeling that modern day atvs offers. janssen and roll design are the 2 companies i know about that offer long travel setup and there both big $$.
what exactly do you disagree about then? you just repeated everything i said about LT.
