Bansheeejohn Posted April 23, 2010 Report Share Posted April 23, 2010 just did new top end turn on gas and starts dripping from carb shifter side out overflow line and and bottom of carb, so when i ride bike starts to break up when im into it more with 3rd 4th 5th and runs crappy, once i get the carb problem sorted out do u think it will run right. Any guesses on whats carb problem.........thanks for any help Quote Link to comment Share on other sites More sharing options...
overrevtricky Posted April 23, 2010 Report Share Posted April 23, 2010 Did you put the float gasket on right? I had mine ass backwards and it did the same thing you explained. Leaked steadily out of the overflow. Quote Link to comment Share on other sites More sharing options...
JKJK Posted April 23, 2010 Report Share Posted April 23, 2010 Either the float is to high or the needle+seat are not sealing correctly or both.The bowl to body surface should be a o-ring seal on those carbs. Quote Link to comment Share on other sites More sharing options...
Bansheeejohn Posted April 23, 2010 Author Report Share Posted April 23, 2010 (edited) both sound like could be im gonna pull carb off this weekend probably.........................just wonderin if any of those problems would cause bike to run crappy breaks up once your into it Edited April 23, 2010 by Bansheeejohn Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 23, 2010 Report Share Posted April 23, 2010 yea because it is flooding out. Quote Link to comment Share on other sites More sharing options...
Bansheeejohn Posted April 24, 2010 Author Report Share Posted April 24, 2010 yea because it is flooding out. its new top end so with my luck lately (crap).......i want to see her screaming after i fix carb..........its the 5th top end since i owned bike with great results everytime so i was due thanks bro! Quote Link to comment Share on other sites More sharing options...
