Pods?
I have been thinking about going to pods instaed of the single K&N, in the airbox! Will they be problematic for me if I occasionally hit water? Do I need to keep the airbox?
Pods and water sucks. Just mod/cut your air box like i did mine, so its basically a splash shield. Then you can run the proflo plate and single clamp on. Then life will still go on :P
acording to Toomey's website they are garbage. Becuase they dont have a long enough intake on them and throws off the harmonic balance inside the the intake. Then they try to sell you a 2 into 1 filter system to ditch the airbox. The reason for the tube between the two cylinders where you put the boost bottle is is for harmonic (sonic) balance. Check out there website expains in much better than me.
I am still trying to find the on switch on my bike.
