AdrenalineJunky Posted April 21, 2010 Report Share Posted April 21, 2010 I got the cases split apart. Damn some of these screws are ridiculous. I can't get the shift star screws out. About broke my wrist and elbow and don't wanna strip them. Any tips? Is it alright to use water and degreaser to clean the inside of the crankcase as I don't have a parts washer or solvent. And finally I noticed that the left rod has a good bit of movement. It has a good bit of room to slide from side to side? Is this not a good thing? I appreciate all the input. Quote Link to comment Share on other sites More sharing options...
Mjv420 Posted April 21, 2010 Report Share Posted April 21, 2010 I got the cases split apart. Damn some of these screws are ridiculous. I can't get the shift star screws out. About broke my wrist and elbow and don't wanna strip them. Any tips? Is it alright to use water and degreaser to clean the inside of the crankcase as I don't have a parts washer or solvent. And finally I noticed that the left rod has a good bit of movement. It has a good bit of room to slide from side to side? Is this not a good thing? I appreciate all the input. Use an impact driver to get the screws out without stripping them. Degreaser and water should be fine, wont get them as clean and quick as a parts washer. The rod can have some side to side movement but I would have someone check it out before casing it back together. Mike Quote Link to comment Share on other sites More sharing options...
AdrenalineJunky Posted April 21, 2010 Author Report Share Posted April 21, 2010 Looks like i'll have to buy me a new tool then lol. I am hoping that I can get a hold of my dads sandblaster. The right rod has a little bit of side to side but the left rod you can slide back and forth quite a bit more. Quote Link to comment Share on other sites More sharing options...
spurdy Posted April 25, 2010 Report Share Posted April 25, 2010 (edited) Looks like i'll have to buy me a new tool then lol. I am hoping that I can get a hold of my dads sandblaster. The right rod has a little bit of side to side but the left rod you can slide back and forth quite a bit more. Impact drivers are only about $20 and great to have. Go back together with a counter socket screw vs the Phillips. I never use a Phillips on anything. The Clymer"s will give you end play and side clearances for your crank. Another $20 well spent. SP Edited April 25, 2010 by spurdy Quote Link to comment Share on other sites More sharing options...
