4strokekilla1987 Posted April 22, 2010 Report Share Posted April 22, 2010 wsm all the way Quote Link to comment Share on other sites More sharing options...
T_Shee Posted April 22, 2010 Report Share Posted April 22, 2010 im running wiseco right now but only because i traded top ends. i had just rebuilt my last top end with wsm platinum series and i was really impressed with the quality. cant say much for durability since i only had maybe 10 hours on them when i swapped. the rings wsm uses are extremely tough looking. they look to be a lot thicker than wiseco rings. my next rebuild will be with wsm pistons, not to mention they are about 50 bucks cheaper Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted April 22, 2010 Report Share Posted April 22, 2010 if they have thicker rings and its not needed, thats more surface area on the bore so there will be more drag = less power. has anyone got pistons weights ? pin and circlips included ? Quote Link to comment Share on other sites More sharing options...
camatv Posted April 22, 2010 Report Share Posted April 22, 2010 i would vote for wiseco's that were built 3-6 years ago. if you look at the bottom there should be a lil bitty W on them. i believe if the W is not there they are the "newer pistons"... wossner and vertex pistons are also nice. used vertex in dirt bikes for a long time.. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted April 22, 2010 Report Share Posted April 22, 2010 if they have thicker rings and its not needed, thats more surface area on the bore so there will be more drag = less power. that is not nesicarily true....depends on how they are designed. also, it may be to help prevent sticking and/or deflection for a longer seal life. another thing about wsm- their ported/windowed piston is the only one made to retain structural strength with the extra boost port and widened windows, as apposed to a modified piston, where you risk it breaking. Quote Link to comment Share on other sites More sharing options...
SLORYDER Posted April 22, 2010 Report Share Posted April 22, 2010 I've been keeping my eye on that as well... I gotta get a new set of slugs for my motor this year, hopefully it's not the case. With the state of the economy, it wouldn't surprise me although I would be dissapointed. Vitos for a stock piped bike. +5 WHP Weisco or wsm for ported bikes because the exhaust duration should already be ideal Quote Link to comment Share on other sites More sharing options...
SD1026 Posted April 22, 2010 Report Share Posted April 22, 2010 wiseco pro lites hea !!!!!!!! they are running strong for me.b ut then again i have a je piston in my 686 raptor and thats running strong also. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted April 23, 2010 Report Share Posted April 23, 2010 speaking of "other aplications" the first thing i looked for when i got the shee was sealed power teflon coated pistons, lol. they had a verry noticable improvement in throttle response and power in the hp454 i built for an airboat.....man, that thing ran Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 23, 2010 Report Share Posted April 23, 2010 speaking of "other aplications" the first thing i looked for when i got the shee was sealed power teflon coated pistons, lol. they had a verry noticable improvement in throttle response and power in the hp454 i built for an airboat.....man, that thing ran Have your own done. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted April 23, 2010 Report Share Posted April 23, 2010 that was my origional plan with the cp-9 friction/ceramic combo from swaintech, like yours......in a prolite....but i heard/saw pics of major galling, but idk if it was oil starved or not......anyways, i decided to go with the wsm ported/teflon piston Quote Link to comment Share on other sites More sharing options...
noscuda Posted May 28, 2010 Report Share Posted May 28, 2010 i dont know about the banshee's yet but i run diamond in a 360/408 stroker sb mopar with 100-300hp of the laughing gas have 5 yrs on them several other problems but same pistons one even has a little ding from a valve still np Quote Link to comment Share on other sites More sharing options...
mercury65 Posted June 5, 2010 Report Share Posted June 5, 2010 well thought i would let this one run a bit to see how long it would take for some one to say that vitos pistons are wisecos funny no one has. Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted June 5, 2010 Report Share Posted June 5, 2010 Wiseco is all I will use! Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted June 5, 2010 Report Share Posted June 5, 2010 wiseco Quote Link to comment Share on other sites More sharing options...
VictorK Posted June 5, 2010 Report Share Posted June 5, 2010 well thought i would let this one run a bit to see how long it would take for some one to say that vitos pistons are wisecos funny no one has. probably because everyone is running wisecos from wiseco, not wisecos from vitos. Quote Link to comment Share on other sites More sharing options...
