DarrenB Posted April 18, 2010 Report Share Posted April 18, 2010 Hi all i have a very new 421 cheetah, it was a complete kit from trinity, but im not sure about the cynlders, as the suplier in Australia had them on the shelf, and his reputation isnt real flash so im not sure on there past. motor was profesionally built, run in , dynoed, and then in its first compeditive race i didnt even finish the first lap. (lap 30 miles long) i got about 28 miles. backed of at the end of the straight and it started dying so i clutched it and pulled over. everything seemed fine so i went to restart and noticed it was low on compression. drove home and stripped it and this is what i found. any ideas on the cause? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 18, 2010 Report Share Posted April 18, 2010 Bad plating but more than likely was it leaking any coolant? Antifreeze leaking in the cylinder is known to flake nikasil. Quote Link to comment Share on other sites More sharing options...
firebanshee Posted April 18, 2010 Report Share Posted April 18, 2010 Do you also have the trinity domes?I WAS running trinity domes at one time and i kept having problems blowing o rings and detonation problems,i switched domes and problem went away.I did not switch dome size so i think they have a bad design.imo Quote Link to comment Share on other sites More sharing options...
doug Posted April 18, 2010 Report Share Posted April 18, 2010 Check out the photos in my post man - seems like we may have the same problem: My link Quote Link to comment Share on other sites More sharing options...
Boston Posted April 18, 2010 Report Share Posted April 18, 2010 Check out the photos in my post man - seems like we may have the same problem: My link you get yours from trinity as well? Quote Link to comment Share on other sites More sharing options...
doug Posted April 18, 2010 Report Share Posted April 18, 2010 Are you referring to the jugs? I am not sure where they originally came from. Does Trinity have problems with there jugs? Quote Link to comment Share on other sites More sharing options...
doug Posted April 18, 2010 Report Share Posted April 18, 2010 Are you referring to the jugs? I am not sure where they originally came from. Does Trinity have problems with there jugs? Crap, sorry, just re-read the post and realized you where referring to the domes. I am not sure - how do I tell? Quote Link to comment Share on other sites More sharing options...
Boston Posted April 19, 2010 Report Share Posted April 19, 2010 i was talking about the cylinders but idk if they got a flaking problem or not Quote Link to comment Share on other sites More sharing options...
DarrenB Posted April 19, 2010 Author Report Share Posted April 19, 2010 Bad plating but more than likely was it leaking any coolant? Antifreeze leaking in the cylinder is known to flake nikasil. no leaking coolant that im aware of, the left cylnder also had it flaking off but only a small amount and up near the top on the intake side. plugs and tops of pistons look like its running sweet, so im a bit confused as to the cause of this issue. what brand domes did you change to? as one of the domes has a fair amount of nickasil hanging out of it, so i have to replace it anyway. the cylinders ,head, domes etc are part of Trinitys complete 421 kit with carbs etc, so what domes will suit this head? thanks guys. Quote Link to comment Share on other sites More sharing options...
