dunner250 Posted April 17, 2010 Report Share Posted April 17, 2010 I just wanted to know what people had luck with. I guessing a smaller rim bigger tire and less tread? I have BFG 16" rim and I tow a 7 by 16 enclosed trailer out in the sand. I have pretty good luck but in the summer when the sand is soft and it has not rain for a while I seem to have some trouble. Airing down to 15 psi seems to help but its getting pretty low. I also see people pulling large 5th wheels and good size trailer and most of them seem to do OK. I also air down the trailer as well Quote Link to comment Share on other sites More sharing options...
alf44 Posted April 17, 2010 Report Share Posted April 17, 2010 Air em down to 10-15 pounds your fronts need to be real low if your in 4 high. Just cruise nice and easy. I run the toyo that everyone has. Im thinking about trying out the nitto dune grappler tire. there specifically for sand and have a flamed side wall. So they look cool to lol. Quote Link to comment Share on other sites More sharing options...
dunner250 Posted April 17, 2010 Author Report Share Posted April 17, 2010 going that low does it ever come off the rim? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted April 17, 2010 Report Share Posted April 17, 2010 I used to run the Wild Country TXRs, but they quit making them in my size. I just put a set of the Toyo Open Country M/Ts on and haven't had them to the sand yet. I used to air down to 20 psi and that worked fine with my setup- 1995 F250HD 4X4 with a 10 ft. slide in camper and a 6.5X12 foot trailer loaded up, total weight was arond 9300 lbs. Make sur you air down EVERYTHING. Also, the dune grapplers are supposed to work really well in the sand. And when it comes to wheel size, most people in the know say your wheel diameter should not be more than 1/2 of what your tire diameter- that means a 15 inch wheel up to 31 inch tire, 16 inch for 32 or 33, 17 for 35 and so forth. If you want 20 inch wheels on your offroader, you should be running 40 inch tires. This is so you have enough sidewall flex to get good traction. Quote Link to comment Share on other sites More sharing options...
chrisp250r Posted May 18, 2010 Report Share Posted May 18, 2010 (edited) go to www.intercotire.com and look at the trxux STS tires those are bad ass in the sand,,, theese guys make all the best off road truck tires hands down Edited May 18, 2010 by chrisp250r Quote Link to comment Share on other sites More sharing options...
chrisp250r Posted May 18, 2010 Report Share Posted May 18, 2010 The TrXus STS, the STS stands for Three Stage Sidewall, is a new concept in all terrain tires. These tires are not intended to be a substitute for the Super Swamper or Bogger tires but a tire for you if you spend a lot of time on the street. Besides working so well on the street it has good off road performance and excels in snow and sand. It is also very much at home in the rocks and will impress anyone with its all around performance. This tire is going to set a new standard in the all terrain category. PICTURE #1 IS THE RADIAL & PICTURE 2 IS THE BIAS PLY Quote Link to comment Share on other sites More sharing options...
firebanshee Posted May 18, 2010 Report Share Posted May 18, 2010 I run a 37x13.50x18 open country toyo and air them down to 15psi in front and 12psi in the rear and pull a fully loaded toy hauler with 100gal of water on board in the sand.I also air the trailer down to 18psi. Quote Link to comment Share on other sites More sharing options...
donkeypuncher Posted May 18, 2010 Report Share Posted May 18, 2010 my dad airs down to around 12psi in the truck and 20psi on the trailor and has zero problems movin around in the sand. he had 38" tsl's and currently runs 37" toyo mt's. both seem to work well. Quote Link to comment Share on other sites More sharing options...
dunner250 Posted May 18, 2010 Author Report Share Posted May 18, 2010 I aired down to 15 psi on bfg this weekend at winchester bay. No problems in the sand, but I was only towing a little 5 by 10 trailer. I guess I'll see what happens memorial day weekend at sand lakes, that is where I always get stuck. Quote Link to comment Share on other sites More sharing options...
johnny boy Posted May 18, 2010 Report Share Posted May 18, 2010 Ive got a 03 chevy 2500 diesel with stock 245/75/16 hwy threads.I go in and out of pismo pulling my 30 ft toyhauler loaded with (2) banshees,(1) trx450,(1) raptor 250.I just drop air pressure to 20lbs all the way around.toyhauler I drop to 15lbs.Now this is empty of water.I carry a 100 gal tank that I run and go fill up and pump it into the toyhauler after im parked. Quote Link to comment Share on other sites More sharing options...
