jrmarquez.702 Posted April 15, 2010 Report Share Posted April 15, 2010 I have a toyota tundra and i was wondering what psi you guys are leaving in your tires so you dont get stuck at the dunes. Its 4wd and we are going to try to make a bar so we can groom the launch for the sand drags. I heard somewhere that guys are leaving 5psi, is that safe? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted April 15, 2010 Report Share Posted April 15, 2010 When I take the truck and trailer out on the sand I air down to 20-25, if the camper is on the truck, then I air down to 20. It is a 95 F250HD with a 9.5 ft. camper and a 6.5X12 flatbed trailer. My Gross Combined Weight is around 9300lbs going down the road with 2 Banshees, my crossbed toolbox and a generator on the trailer. I would not recomend airing down to 5 psi unless you have beadlock wheels, actually I would not go below 15 psi without beadlocks, because when you turn a corner you will roll the tire bead right off the wheel. Quote Link to comment Share on other sites More sharing options...
dunner250 Posted April 15, 2010 Report Share Posted April 15, 2010 I don't like going below 20psi. But there has been times that 14-12 psi is the only thing that is going to get me unstuck. Thats with a chevy 1/2 ton towing a 7 by 16 enclosed trailer. I went between 20 to 25 on the trailer. I start at 20 and when they start to spin I just stop and air them way down. There is nothing worse then getting stuck on a busy weekend with no one helping and your wife flapping her lips on a hot day while your trying to get unstuck. Quote Link to comment Share on other sites More sharing options...
jrmarquez.702 Posted April 15, 2010 Author Report Share Posted April 15, 2010 That's true! I mostly only tow in a few banshees to the hill, but when I'm towing the rest of the stuff on the road I keep my tires at 60 psi. Thanks guys, I think that I'll try 20 psi next time. Now that I think about it, the guy that said go to 5 psi had beadlocks. Quote Link to comment Share on other sites More sharing options...
