Thewhite Posted April 13, 2010 Report Share Posted April 13, 2010 I done a leak down test on my new RZ350 set-up and I got the following: start with 6 PSI end up with 5 psi at 6 minutes end up with 4 psi at 12 minutes From what I heard, the test was to hold 6 psi for 6 minutes. Is my results are acceptable ? thnaks, Martin Quote Link to comment Share on other sites More sharing options...
blowit Posted April 13, 2010 Report Share Posted April 13, 2010 I done a leak down test on my new RZ350 set-up and I got the following: start with 6 PSI end up with 5 psi at 6 minutes end up with 4 psi at 12 minutes From what I heard, the test was to hold 6 psi for 6 minutes. Is my results are acceptable ? thnaks, Martin I would not sweat that a bit. You are not always going to seal at the shaft seals with this type of test. Run it B Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 14, 2010 Report Share Posted April 14, 2010 I'd run that and not even think twice about it...more than 1PSI per minute is cause for alarm. And usually when you have a bad leak (crank seals or intakes) it'll spit out as fast as you can pump air in there. Quote Link to comment Share on other sites More sharing options...
