zach45 Posted April 10, 2010 Report Share Posted April 10, 2010 i need the little brass clip think that holds the carb cable in place... you can only buy the whole slide new for 25 each.... i only need the 2 brass clips... thanks zach Quote Link to comment Share on other sites More sharing options...
AKheathen Posted April 10, 2010 Report Share Posted April 10, 2010 i need the little brass clip think that holds the carb cable in place... you can only buy the whole slide new for 25 each.... i only need the 2 brass clips... thanks zach not quite sure what you are talkin about on the cable retainers? there's only steel, and aluminum peices..... Quote Link to comment Share on other sites More sharing options...
SandmanPNW Posted April 10, 2010 Report Share Posted April 10, 2010 not quite sure what you are talkin about on the cable retainers? there's only steel, and aluminum peices..... ohhhhhhhhhhhhhhhhhh................... These little gems right here? Quote Link to comment Share on other sites More sharing options...
blackedout96 Posted April 11, 2010 Report Share Posted April 11, 2010 I've had to buy those from a dealer before, I think it was a "needle set" or something like that I had to buy. Was only about $10. I may actually have some in the garage for you though.... I'll check. Quote Link to comment Share on other sites More sharing options...
john45 Posted April 12, 2010 Report Share Posted April 12, 2010 yes i need those clips send them this way... Quote Link to comment Share on other sites More sharing options...
