Pro circuit jetting
AJrod12
I have been searching bansheehq for a while now but never had any questions that I couldn't find the answer to without searching so I never introduced myself. Great site by the way.
Well I bought my banshee about 2 years ago. It is a 2005 all stock and I just decided to buy some pro circuits. I'm kind of a new to jetting so I was wondering what size jets I should use. Elevation is about 30 feet above sea level (I think) and I want to keep the airbox lid on. The temp ranges anywhere from 75-95 degrees in the summer. Thanks for the help.
had similar setup except i had a k&n filter... i would start off with 27.5 pilots and 280 mains and that should set you close to perfect but every bike is different so do a plug chop and make sure to get a variety of jets so u can get it right cause the last thing u want to do is burn her down.
  • 3 weeks later...
Well I finally got everything together the other day. I put in 280 mains and 27.5 pilots and turned the air screws out 1.5 turns. It is very sluggish so i figure I am too rich. I'm going to try out some 260 mains and see what happens. Any other suggestions? Thanks
describe the sluggish better, and conditions.....was it sputtering? what throttle range? was it warmmed up to operating temp? was it like a delay in response, or hesitation? bogging? might be more than just the main size, as the main sets the wot operation only.
