Wheelman Chassis Posted April 6, 2010 Report Share Posted April 6, 2010 hey guys, my mods are in my sig. how hard should ihave to pull up on the shifter to get my tranny to shift?? somtimes it shifts good with a moderate pull up, but a few times at silverlake this weekend it seemed like it wouldnt shift or i had to yank real hard up on the shifter...i havent backloaded it hard or anything that i can tell, and its never made any noise or grinding...i need some info in a hurry...ive got to be ready for the hq silver lake ride.... thanks guys chris Quote Link to comment Share on other sites More sharing options...
tundish2800 Posted April 6, 2010 Report Share Posted April 6, 2010 do a oil change and make sure you don't have any chunks of metal coming out. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted April 6, 2010 Report Share Posted April 6, 2010 You arent spinning bad right? If traction is bad, it wont shift. As for your questions, not sure. I just took my shift pro shift kit out. Getting used to the stock feel now which is a lot harder to shift now Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 6, 2010 Report Share Posted April 6, 2010 youre right on the edge man. you have enough power now that youre going to start having shifting issues. you would absolutely benefit from a duneable override and a lockup. Quote Link to comment Share on other sites More sharing options...
VegasJeff Posted April 6, 2010 Report Share Posted April 6, 2010 Did you change to ATF type "F" and install the stock shift star? Quote Link to comment Share on other sites More sharing options...
J-Madd Posted April 6, 2010 Report Share Posted April 6, 2010 hey guys, my mods are in my sig. how hard should ihave to pull up on the shifter to get my tranny to shift?? somtimes it shifts good with a moderate pull up, but a few times at silverlake this weekend it seemed like it wouldnt shift or i had to yank real hard up on the shifter...i havent backloaded it hard or anything that i can tell, and its never made any noise or grinding...i need some info in a hurry...ive got to be ready for the hq silver lake ride.... thanks guys chris Oil change usually fixes that for me. The dogs will sometime gets burrs on them that have to be smoothed out, though. I had to take a tranny apart to fix that; but I still had issues when the oil got dirty (ATF type F.) Quote Link to comment Share on other sites More sharing options...
Wheelman Chassis Posted April 7, 2010 Author Report Share Posted April 7, 2010 youre right on the edge man. you have enough power now that youre going to start having shifting issues. you would absolutely benefit from a duneable override and a lockup. i do have a dunable overide and lockout..lol as for other answers ive only ran 80w oil,yes it was spinning hard at times, as for the shift star im not sure, i got the motor complete and haven tlooked i really dont want to tear this thig down and have to rush it back together,atf-f make it shift better? Quote Link to comment Share on other sites More sharing options...
Wheelman Chassis Posted April 7, 2010 Author Report Share Posted April 7, 2010 do a oil change and make sure you don't have any chunks of metal coming out. just changed the oil, no metal...this has happend once on the concrete racing a 10 mil and once at silverake gofing off (spinning bad),all other times it shifts good just seems to take alil more than i expected to shift it..this is my first override by the way Quote Link to comment Share on other sites More sharing options...
VegasJeff Posted April 7, 2010 Report Share Posted April 7, 2010 just changed the oil, no metal...this has happend once on the concrete racing a 10 mil and once at silverake gofing off (spinning bad),all other times it shifts good just seems to take alil more than i expected to shift it..this is my first override by the way I'm betting the star is the correct one,being it shifts through all the gears and neutral is down.We changed to the ATF and never looked back and it shifts alot better.our whole group runs cubs with the duneable overrides and the ATF,no problems yet. Quote Link to comment Share on other sites More sharing options...
firebanshee Posted April 7, 2010 Report Share Posted April 7, 2010 Ditch the 80wt try ATF. Quote Link to comment Share on other sites More sharing options...
Wheelman Chassis Posted April 7, 2010 Author Report Share Posted April 7, 2010 Ditch the 80wt try ATF. ok so im going to get type f fluid and try that, like i said it only once and a while i have a problem..so it doesent sound like a shift fork right?? also how dunable are these things?? Quote Link to comment Share on other sites More sharing options...
firebanshee Posted April 8, 2010 Report Share Posted April 8, 2010 ok so im going to get type f fluid and try that, like i said it only once and a while i have a problem..so it doesent sound like a shift fork right?? also how dunable are these things?? Redline Racing cut mine, i have backloaded mine and it still shifts like butter. I pretty much ride it like a normal trans, except when racing. I love my duneable override, one of the best mods i have ever done to my bike. If it was a fork it seems like it would be hard to shift all the time. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 8, 2010 Report Share Posted April 8, 2010 i have a 2-4 duneable by Redline Racing and a lockout. i run cheap advance auto parts 10w40 in mine. shifts like butter. Quote Link to comment Share on other sites More sharing options...
GrayRacing Posted April 13, 2010 Report Share Posted April 13, 2010 i ran into this problem b4. its wither wore out forks, or ur just putting pressure on the gear shifter. ive went through 2 or 3 cut trannys, lol Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 17, 2010 Report Share Posted April 17, 2010 The dunable overrides are very durable if you don't backload the living hell out of them. The few we've had come back were backloaded like a trail bike and the owners fully admitted to that... I've had mine in my 10 mil for 3 seasons...split my cases yesterday and the trans still looks fantastic. If the tranny was cut right, you should have no issues. 80w in an override is definitely a problem. Run 2 full qts of ATF Type F. Change it every other ride. Quote Link to comment Share on other sites More sharing options...
