boost bottle
i have a 2003 banshee with pro circut 305 pipes,.10 over. this is all i have on it. would jets be a good investment.
Yes, you should have re-jetted it after you put the pipe on - otherwise your not getting the full use of those pipes. Agree with the guys above the boost bottle doesnt do much.
Most cost effective way of getting a big bump in horsepower (this requires you to have some basic mechanical skills)
1. Remove your cylinders and cut (raise) the roof of your exhaust port exactly 2 millimeters. Do this on each cylinder and make sure you take the same off each one. Do this by keeping the shape of the exhaust port as close to stock as you can. This will require widening the port a bit-no more than 1mm from each side. Blend the widened exhaust window and raised roof into the port leaving a smooth transition from window to exhaust port flange. Chamfer the port edges. Make sure you clean all the metal shavings away and wash in soap and water.
2. Get a set of K&N pods and a jet kit and dial in your jetting
3. Shave your stock head (the amount depends on your elevation you can go at least .025" and be on premium fuel.
Total bucks you would spend less than $200 and you would be extremely pleased with the results.
Stay away from a boost bottle, it won't give you any power and you will end up with cracks in your intake boots from the bottle bouncing around on them. If you just want to go the bolt on route, then I recomend pipes, better intake breathing by removing the air box lid or goinig to a 2into1 or indiviual pod filters, a cool head or milled and chambered stock head, advancing the timing 4 degrees by either modifying the stock plate or a Chariot Performance plate, better reeds by porting the stock cages and using Boyesen petals or a V Force 3 setup in that order. From there you are looking at porting and other internal motor work. There are also several mods that should be done for reliability- weld the crank, pancake bearing, billet impeller, etc. There are also some mods for rideability- shift star, shift shaft mod, better shocks, proper tires for where and what you ride, etc.
Oh, I didn't mention that after every mod for power, you will need to jet the bike properly.
DAMN, you guys are ALL ignorant of th potential of a boost bottle. When you install it you leave it on forever, when the intakes cranj and toast the motor you go 4mil stock cyl, then when it happens again you go 4 mil cub,...rinse and repeat. :rotflmao:
