EVERY USED BANSHEE PART! in stock ready to ship
I part out Yamaha Banshees, I have every factory part you need, and many aftermarket parts as well.
My aftermarket parts are all listed on ebay: EBAY AUCTIONS CLICK HERE
I also have all stock parts on ebay too
Let me know what you need: minkia38@gmail.com
Frame components
J Frame $50.00 (titled add $100), A-arm frame, $225 (titled add $100),
Steering stem $25.00
A-arms / J-arms with brakes, hubs, spindles, and tie rods $250.00
Swingarm $20.00
Axle $100.00
Bearing carrier $50.00
Footpegs $15.00
Nerf Bars / Metal Heel guards $75.00, add $75 for plastic heel guard pieces
Rear Hubs $35.00
Rear Sprocket & Hub $15.00
Rear Brake disc & Hub $15.00
Dogbone $10.00
Rear Grab Bar $20.00
Front Bumper Pushbar $50.00
Shifter $10.00
Skid Plate $20
Running Engine $1000.00
Rubber intake boots/Boost $30.00
Reeds and cages $20.00
Carbs and cable $90.00
Airbox (or air filter) $50.00 - $100.00
Kickstarter $50.00, Rebuilt kicker: $60
Gas Tank $25.00, $15 for one with bad fenders mounts
Pipes $35.00 stock - $300.00 chrome aftermarket
motor parts:
cylinders $300
crank $150
shift drum, rods, forks $15
gears/tranny $100
cases $100-$200
clutch cover with impeller $40, full mirror polished: $125
plastic stator cover $ 15
stator & timing plate $125
internal bolts $25
head $20, $10 pitted inside
flywheel $110
Plastic
Front & rear Fenders $100 - $300
Radiator Plastic $35
Gas Tank Plastic $35
Seat w/ latch $40-$100
Front Fender brackets $15
Electrical
CDI Box $60.00
Wiring harness / Loom $50.00 - $80.00
Coil $20.00
Headlights $80.00
on/off switch $25.00
Key w/ plastic housing $40.00
Taillight $20.00
Misc
Rear brake setup $110.00
Bolt set $25.00
Rear Shock $75.00
Front shocks $75.00
Front tires & rims $75 - 150.00 varies
Rear tires and rims $75 – 150.00 varies
Handlebars & grips $10.00, aftermarket with pad $20
Clutch lever / perch $10.00
Thumb Throttle assembly $25.00
Radiator w/ Reservoir & lines$25.00, Radiator only- $20
Front brake lines $10.00
Front brake lever/rezzy $15.00
Motor Mounts $10.00
Polished clutch covers: $120 shipped for HQ members
ooooh hell of a deal for the hq menbers,not. hes got them for sale on ebay 113 shipped, how is this a deal this guy is a tool! hey ya got any titles with a chunk of frame for sale?lol gtfo :shootself:
well ive beard good and bad . i agree shipping prices are a lil high but when u need something hes got it pretty much, he was gonna knock a few dollars off for shipping for me but i screwed that up my mistake hopefully ill at least get the bolts for the pegs. ill keep you all updated but i DO understand that these parts i am buying are USED!!!!!
As far as high shipping, if you have $50 to spend on a part, does it matter is the part is $40 and $10 shipping, or $45 and $5 shipping? Either way, its the same out of pocket cost for you....
I have higher shipping, becuase of my international customers. When I ship to Canada, its TWICE the USA shipping price, and when I ship elsewhere its THREE times the shipping price.
By having the DOUBLE and TRIPLE style pricing, its makes my life much easier, so I don't have to answer 200 emails a day asking how much shipping a coil is to South Africa or how much to ship a swingarm to Australia.
Because of this, I actually LOWER the item price itself, and add a little shipping, so that it will cover the international rates IF it goes that way.... Either way, the USA customer pays the same amount for the shipped item, Simple economics :)
Plus, any local customers get an even better deal if they pick up!
WTB OEM swing arm skid plate, I looked at your auctions on ebay but need the required hardware as well. How much shipped to 84118?
Hello!
You can just use any old 12mm or 1/2 inch bolts and nuts to mounts the swingarm, you don't need any special hardware....
Hello!
I havent got down there and looked, I bough it last fall and and want a skid plate for it. in that case ill get on ebay and buy it. Do you give discounts to BHQ members?
  • 2 weeks later...
