jimp1967 Posted March 29, 2010 Report Share Posted March 29, 2010 My banshee has a AMP link on it and I'm removing it and going back to the stock set-up, are the chain slider set-ups good to go with? Or should I just go with the factory guide on the swing arm and new rollers? Jimmy Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted March 29, 2010 Report Share Posted March 29, 2010 Get the chain slider to go around the pivot tube and you need to have at least the lower roller on the frame. I have been running mine this way ever since I took my AMP link off. The factory roller thing that goes around the pivot tube does not lasr very long and when it wears through, then your chain is sawing into your swingarm. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted March 29, 2010 Report Share Posted March 29, 2010 Best chain slider, rolers, and rear guid out there is TM Design works. The rolers have a lip on them that help guid the chain. The rear guid also has 2 rollers so there is less drag. All the plastic is oil impregnated so it has less drag and extends the life of the parts. The down side is that it is more expensive. You can buy parts seperate too. Rollers. http://www.tmdesignworks.com/index.php?main_page=product_info&cPath=189_191_179&products_id=317 Front swing arm slider. http://www.tmdesignworks.com/index.php?main_page=product_info&cPath=64_97&products_id=122 Rear guide. http://www.tmdesignworks.com/index.php?main_page=product_info&cPath=67_182&products_id=332 Whole Kit. http://www.tmdesignworks.com/index.php?main_page=product_info&cPath=204_203&products_id=373 Quote Link to comment Share on other sites More sharing options...
