Chain slider?
jimp1967
Get the chain slider to go around the pivot tube and you need to have at least the lower roller on the frame. I have been running mine this way ever since I took my AMP link off. The factory roller thing that goes around the pivot tube does not lasr very long and when it wears through, then your chain is sawing into your swingarm.
Best chain slider, rolers, and rear guid out there is TM Design works. The rolers have a lip on them that help guid the chain. The rear guid also has 2 rollers so there is less drag. All the plastic is oil impregnated so it has less drag and extends the life of the parts.
The down side is that it is more expensive. You can buy parts seperate too.
Rollers.
http://www.tmdesignworks.com/index.php?main_page=product_info&cPath=189_191_179&products_id=317
Front swing arm slider.
http://www.tmdesignworks.com/index.php?main_page=product_info&cPath=64_97&products_id=122
Rear guide.
http://www.tmdesignworks.com/index.php?main_page=product_info&cPath=67_182&products_id=332
Whole Kit.
http://www.tmdesignworks.com/index.php?main_page=product_info&cPath=204_203&products_id=373
