SLORYDER Posted March 26, 2010 Report Share Posted March 26, 2010 Ok it's gonna be on a fully drag ported 350 w/ 34mm carbs/ cpi pipes j arm frame with 160 lb rider. Also gonna be that heavy sand with the little bitty pebbles in it (LA Dunes) Thanks Quote Link to comment Share on other sites More sharing options...
SLORYDER Posted March 26, 2010 Author Report Share Posted March 26, 2010 Also not sure the gearing but the guy says it is geared to run right at 100mph in 6th and I believe the front sprocket is a 15 or a 16 Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted March 26, 2010 Report Share Posted March 26, 2010 Need more info. On alky or out of frames will pull more tire and need more arm. On gas and inframes to play and dune a +6 and 9 or 10 paddles. Quote Link to comment Share on other sites More sharing options...
SLORYDER Posted March 26, 2010 Author Report Share Posted March 26, 2010 Need more info. On alky or out of frames will pull more tire and need more arm. On gas and inframes to play and dune a +6 and 9 or 10 paddles. Inframe pipes. Pump gas I have a +8 and some 11 paddle tripple buffs right now but I run tubes in 'em and don't know if I can get the pressure low enough top bite outa the hole.. Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted March 26, 2010 Report Share Posted March 26, 2010 Probably a +6 then and a 10 paddle extreme since the jocky is light. That's what my buds and I ran for years and had fun dune racing. If you use an 8 over you'll wanna run 11s probably. Quote Link to comment Share on other sites More sharing options...
randomrider Posted March 27, 2010 Report Share Posted March 27, 2010 i wouldnt get your hopes up on it running 100 mph Quote Link to comment Share on other sites More sharing options...
SLORYDER Posted March 27, 2010 Author Report Share Posted March 27, 2010 I'm sure with the mods listed I could easily run 100 mph on asphault I was just giving you a rough estimate of my gearing. Seems like a +8 would be short for dragging I could be wrong though.... Quote Link to comment Share on other sites More sharing options...
