VictorK Posted March 25, 2010 Report Share Posted March 25, 2010 can somebody please tell me the amount of plates the clutch has fiber and steel? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted March 25, 2010 Report Share Posted March 25, 2010 7 fiber 6 steel. Start and end with a fiber when installing. Quote Link to comment Share on other sites More sharing options...
VictorK Posted March 25, 2010 Author Report Share Posted March 25, 2010 I thought so but I just picked up my first banshee 3 weeks ago and I went to install a cascade shift star and there was 7 friction and 7 steel I knew it wasn't right but wanted to be sure there was 2 steel against each other some people are just hackers 7 fiber 6 steel. Start and end with a fiber when installing. Quote Link to comment Share on other sites More sharing options...
00sheerzr Posted March 26, 2010 Report Share Posted March 26, 2010 glad to see another ct rider ,welcome Quote Link to comment Share on other sites More sharing options...
VictorK Posted March 26, 2010 Author Report Share Posted March 26, 2010 glad to see another ct rider ,welcome thanks man theres lots of CT riders I have like 4 friends with banshees even we just need the riding spots the DEP is supposed to be setting aside Quote Link to comment Share on other sites More sharing options...
dajogejr Posted March 26, 2010 Report Share Posted March 26, 2010 Some people run 2 steels side by side in the middle of the clutch pack, you get better grab. I did for a while until I switched lockups... That's what someone means by an extra steel or extra plate when they're talking about a stock clutch setup. Quote Link to comment Share on other sites More sharing options...
VictorK Posted March 26, 2010 Author Report Share Posted March 26, 2010 Some people run 2 steels side by side in the middle of the clutch pack, you get better grab. I did for a while until I switched lockups... That's what someone means by an extra steel or extra plate when they're talking about a stock clutch setup. does it matter where in the middle they are with no friction plate between? and do you think I should stay with that? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted March 26, 2010 Report Share Posted March 26, 2010 What kind of bike do you have/what are your mods? Quote Link to comment Share on other sites More sharing options...
VictorK Posted March 26, 2010 Author Report Share Posted March 26, 2010 The performance mods are gnarly pipes with powercore 2s,adj timing plate +4'tors eliminators/jetted carbs 310 main and 27.5 pilot,power reeds,60 over wisecos being done right now and shift star that's it for now I've only had it for just under a month and I've made lots of progress What kind of bike do you have/what are your mods? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted March 26, 2010 Report Share Posted March 26, 2010 does it matter where in the middle they are with no friction plate between? and do you think I should stay with that? By running the extra plate you are preloading the clutch springs more. It is also reducing the clearance between the plates when you pull the clutch lever, which will cause the bike to lunge forward because they are not releasing cleanly.Also, with the extra plate, is the pressure plate spline properly meshing with the clutch hub splines? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted March 26, 2010 Report Share Posted March 26, 2010 By running the extra plate you are preloading the clutch springs more. It is also reducing the clearance between the plates when you pull the clutch lever, which will cause the bike to lunge forward because they are not releasing cleanly.Also, with the extra plate, is the pressure plate spline properly meshing with the clutch hub splines? Untrue. I had this on my 4 mil cub motor with NO lockup and it didn't lunge. I had it adjusted properly as well as a new clutch cable, not a stretched out one. The plates barely need any separation to engage/disengage. There is more than enough room even on a stock setup (basket/inner/outer hub) to run an extra steel and have it mesh properly. However... With our mods, I truly feel you don't need it, to be honest. Quote Link to comment Share on other sites More sharing options...
