jonpeter0420 Posted March 24, 2010 Report Share Posted March 24, 2010 what can i expect to gain from removing my tors and what do i need to replace them with? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted March 24, 2010 Report Share Posted March 24, 2010 You will need a complete TORS removal kit- it will include a new throttle cable to match your throttle(twist or thumb), 2 new carb tops, 2 idle screws with locknuts, a tap for the idle screws and maybe a drill bit and some instructions. You will need to disconnect the TORS wiring at the carbs, thumb throttle and the control box under the left side of the fuel tank next to the coil. You will then remove your carbs, disassemble them, grind down flat the boss on the side of the carb where the idle screw will be installed, drill and tap the carb, clean the carb and re assemble them with the new round top instead of the TORS top. You will then have to adjust the idle speed and sync the carbs. You will gain much easier access to your carbs and other things on the bike for maintenance, and you will not have to worry about the TORS failing and causing the bike not to run, that is especially good when you are out in the middle of nowhere. Quote Link to comment Share on other sites More sharing options...
MN SHEE Posted March 24, 2010 Report Share Posted March 24, 2010 X 2 ^^^^^^^^^^^^^^^^ Quote Link to comment Share on other sites More sharing options...
fastquad02blaster Posted March 25, 2010 Report Share Posted March 25, 2010 How often do they quit? Any warning signs or since they're electrical do they just up and quit? Quote Link to comment Share on other sites More sharing options...
FrankieSquid Posted March 25, 2010 Report Share Posted March 25, 2010 How often do they quit? Any warning signs or since they're electrical do they just up and quit? They are really common for failing rather than helping the rider out. No warning signs. One day you can be riding and the next day your sitting in your garage sad because your shee mysteriously does not start anymore. With tors people get a lot of no start problems. take that shyt out Quote Link to comment Share on other sites More sharing options...
alf44 Posted March 25, 2010 Report Share Posted March 25, 2010 Shoot me a pm when your ready to get one. Ill get you a great deal on it. Ive been selling about 3 a month. At the best price i can offer. Quote Link to comment Share on other sites More sharing options...
