Stretched cable? How olds the cable? Did you lock down the adjuster on top of the carbs? I guess i should ask if you still have to tors also...
when ever i sync my carb slides then i ride it then if i check them later they will be out of sync why?? :confused::confused::confused:
They shouldn't be that far out. But what I like to do is sync 'em by eye then ride it around for a bit before I get on 'em with the sync tool. I have found that they will move some after you first get 'em put back together due to the spring and the cable not being fully seated in their "homed" positions. I think that the spring shifts a little and can relax some of its tension if you put it in the slide and then you have to rotate it one way or the other to line it up. Same with the cable it could be slightly twisted one way or the other until you pull it a few times. Also, you have to make sure that you have the cap tight and if you don't have the TORS, make sure the cable ends are completely seated in the caps (dirt free) with the boots pulled down.
