CarvedArt Posted March 20, 2010 Report Posted March 20, 2010 I have a stock 97 and I just added a few mods. I'm just looking for some reasonable place to start as far as jetting is concerned. Stock carbs TORS removed idle kit installed Mix = 32:1 Elev = 3222 ft asl Humid = 0-30% Base jetting: Slide = 2.0 Pilot = 25 Needle = Y151, 3rd groove from top Main = 200 Air = 1.5 turns ...Ran perfect. Added/Modded: Switched the coil leads, put the pos on the (+) and the neg on the (-)Toomey T5's w/ sparkysToomey 2:1 High Flow Air Filter Toomey says: Pilot = 25 Needle = Y151, 4th groove from top Main = 280 or 270 for higher elev Air = 1.5 turns Elev = Sea Level My math says: Pilot = 25 - 27.5 Needle = Y151, 3rd - 2nd groove from top Main = 290 - 310 Air = 1.5 - 2 turns What jets should I start with? ...Thanks for your help! Quote
GrMeyer Posted March 21, 2010 Report Posted March 21, 2010 I would start out with Main - 300 depending on temp. 310 if your in the 40deg's Needle - Middle Pilot - 27.5 Airscrew - 1-1/2 turns from fully seated. Make sure the carbs are synced or you will have shitty bottom end. Quote
CarvedArt Posted March 21, 2010 Author Report Posted March 21, 2010 I would start out with Main - 300 depending on temp. 310 if your in the 40deg's Needle - Middle Pilot - 27.5 Airscrew - 1-1/2 turns from fully seated. Make sure the carbs are synced or you will have shitty bottom end. Thanks for the input! I'm in the 80deg's right now, normally average between 80 - 95. So I guess I'll start with the 300 Main, 3 on the Needle (middle), 27.5 Pilot, and 1.5 turns on the Air. As for the sync I've got an EMPI (snail) so I'm keeping that in check too. Thanks again. Quote
