blowing orings
shrimp
Yea, what the other guys are saying. I wouldn't recommend 20cc domes on a stock motor at sea level on pump gas. Detonation will lift the domes and blow the oring. When you put it back together, run larger domes or higher octane (or both).
-David
hey david i talked to you about a year ago.
its the same problem
its a 4mill cheetah cub. no porting
You are going to have to keep your compression down around 155-160, probably have to have a 23 or 24cc dome. I am sure Noss can hook you up. B)
thanks all
i just talked to kevin and i need to change the domes to 24's
i was wrong on the domes i had they are 21's
i ordered the new parts.
