NVRBanshee Posted March 14, 2010 Report Share Posted March 14, 2010 i just got back from the dunes racing and well i could not get my bike out of the hole it a stock stroke drag port with 34mm carbs on the bottle, +10 swingarm 22-11-10 12paddle haullers. 14-42 gearing racing 300ft sand i didnt even run the bottle cuz i couldnt hook up. any help please Quote Link to comment Share on other sites More sharing options...
shanYE west Posted March 14, 2010 Report Share Posted March 14, 2010 tire pressure? Quote Link to comment Share on other sites More sharing options...
NVRBanshee Posted March 14, 2010 Author Report Share Posted March 14, 2010 tire pressure? i tried 10psi down to 4psi Quote Link to comment Share on other sites More sharing options...
tundish2800 Posted March 15, 2010 Report Share Posted March 15, 2010 what are you running in the rear a shaw, stock shock, strut? Quote Link to comment Share on other sites More sharing options...
NVRBanshee Posted March 15, 2010 Author Report Share Posted March 15, 2010 what are you running in the rear a shaw, stock shock, strut? stock shock Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted March 15, 2010 Report Share Posted March 15, 2010 Try a 15 tooth counter shaft sprocket, it should help out quite a bit. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted March 15, 2010 Report Share Posted March 15, 2010 I was using 15/42 or 14/40.. I was using 13 extremes with 2lbs of pressure. worked the best for me. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted March 15, 2010 Report Share Posted March 15, 2010 You need more than a stock shock for 10 over arm, or at least a heavy spring. The soft shock is sagging and absorbing all your launch inertia. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted March 15, 2010 Report Share Posted March 15, 2010 Yep... That'll do it Jeff. Not to mention the shock length. Makes it tall in the ass and transfers weight to the front of the bike. Quote Link to comment Share on other sites More sharing options...
Wheelman Chassis Posted March 15, 2010 Report Share Posted March 15, 2010 im kinda in the same boat as the poster i have a +12 arm, what do we do for a shock and is a stiff rear better then a soft one for dragging? Quote Link to comment Share on other sites More sharing options...
shanYE west Posted March 15, 2010 Report Share Posted March 15, 2010 im kinda in the same boat as the poster i have a +12 arm, what do we do for a shock and is a stiff rear better then a soft one for dragging? marvin shaw shocks is the best option.. Quote Link to comment Share on other sites More sharing options...
Wheelman Chassis Posted March 15, 2010 Report Share Posted March 15, 2010 can the shaws be adjusted for a heavy rider without sending it out to them? and do we have to have the front shaws to? i have elkas in front already set for my weight 260lbs Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted March 15, 2010 Report Share Posted March 15, 2010 We can sell you a hvy spring for your stock shock. Quote Link to comment Share on other sites More sharing options...
NVRBanshee Posted March 15, 2010 Author Report Share Posted March 15, 2010 We can sell you a hvy spring for your stock shock. How much? thanks for all the help Quote Link to comment Share on other sites More sharing options...
Wheelman Chassis Posted March 16, 2010 Report Share Posted March 16, 2010 yea jeff,how much and what weight is it for? Quote Link to comment Share on other sites More sharing options...
