need help asap
I had FMF pipes and a Toomey 2 into 1 air filter and it needed 270 mains and 27.5 pilots, it needed the 27.5 pilots with just the air cleaner. Also check your reed petals,that can make it backfire and not run on a cylinder. It definetly sounds like it could be a fuel problem but your compression is a little low also. When you cleaned the carb, did you pull all the jets out and blow air through all the passages and make sure that they are open? One other p[ossibility is the float bowls got mixed up, they are different from the left carb to the right carb. Good luck.
