need help asap
ok i have a right cylinder back fire at low rpm and only idles on one cylinder.when i pull the choke out it runs on both cylinders and the back fire goes away.so i took it apart and found a pin hole in the cross over tube betweenthe carbs.so i covered the hole up and started it and it still seemed to have a back fire.i checked both carb boots and there perfect.all the gaskets are good,this was the only thing i could find.the carbs have 250 mains and 25 piolet.the bike is all stock except for the exhaust.full fmf gnarly pipe.its also around 50 deg.at sea level.any help would be great.thanks for ur time
has it always run like this....or did you just pick up the bike? Did you put the fmf's on? your gonna have to fix that choke tube...that'll lean you out. and also you may need to step up your pilot jet from the stock size (25) to a 27.5 Sounds like something my bike was doin when i first bought it.....fmf fattys...idled bad and popped and had no bottom end when in gear but it would rev in neutral just fine. Tore the carb jetts out and put in the 27.5....wow did it change alot.
i just got the bike and its run like this from the day i got it.the choke tube has a good connection.i also just checked and im 489 feet above sea level
I'm not saying you don't have a jetting issue, but I think the root of your problem sounds like carb sync. Also check that you have a good connection between you spark plugs and plug caps. You can switch the plug wires and see if the problem moves to the other cylinder to rule out electrical issues.
k did the plug wire thing and it stays at the right cylinder.i even put new plugs in it.pulled the right wire while running and it didnt make a difference.pulled the left one and it shut down.so it acts like its not getting gas for some reason
Have you taken you carbs apart yet and cleaned the shit out of them??
They could be dirty inside..
You should have a leak down test done, I had a problem simaliar to yours and it was a air leak and I ended up frying the motor in glamis. :cry::cry:
I would do a leak down and compression test and than go from there before you hurt the motor.
Just my opinion
Just my opinion
k thanks will do.i have done the carbs a couple times thinking there was stuff coming from the tank but was very clean in carbs every time.ill do leak down test and check compression
k well so far ive done a leak down test and it held 6lbs for 30 min with no loss.now i gotta get a compression tester to do the test.what should stock have for compression
have you pulled the carbs apart to clean them out? and have you tried the 27.5 jets yet? they're not expensive....they're like $3 a piece X 2....so $6 total
ya ive cleaned the carbs many times now.i did both test to it also.leak down and compression.it passed the leak down with no problems and the compression test was 100 psi in both.im still not seeing the problem.where can i buy the 27.5 piolet jets.i did order a jet kit for it.it has 250 mains right now and the only mods are the fmf pipes and box lid
  • 2 weeks later...
