87sheerips Posted March 12, 2010 Author Report Share Posted March 12, 2010 can u get pics of the pistions Pistons are Sold, see above. Can you get a pic of the clutch perch Its in good shape man, believe me. It works fine, if you want it let me know. I wont be able to get pics until tomorrow if u really need to see more detail. Everything that has been paid for has been shipped. Thanks guys, and still a lot of parts left! Quote Link to comment Share on other sites More sharing options...
bad 350 shee Posted March 12, 2010 Report Share Posted March 12, 2010 o ok sorry about that man Quote Link to comment Share on other sites More sharing options...
BluBanshee98 Posted March 13, 2010 Report Share Posted March 13, 2010 So is the stock axle lock nut sold? If not could I see a pic of it? Thanks Quote Link to comment Share on other sites More sharing options...
Tony T Posted March 13, 2010 Report Share Posted March 13, 2010 I need front break lever n cylinder shipped to 08108 Quote Link to comment Share on other sites More sharing options...
87sheerips Posted March 15, 2010 Author Report Share Posted March 15, 2010 STILL AVAILABLE as of 3/15/10: 1. Trinity Stage IV Pipes, stainless, very nice, need cleaned and polished: $350 3. Front rim and tire: 21x7x10 One silver, one gold available: $40 each 5. Gas tank, fender bolts stuck in it, comes with petcock and cap: $20 6. Radiator hoses (3): $15 7. Gas tank plastics: Red, needs clips $20. Red with Graphic, one broken tab, needs clips $15 8. Complete rear brake system w/stainless line up to +12” swinger. Fair pads. $80 10. Rear brake caliper w/stock line, no pads. $20 11. Stock head, great shape: $15 12. Stock rear brake lines, 4 available: $8 each. Will work for up to +4 swingarm. 13. Stainless rear brake line, up to +4 swingarm: $20 15. Useable used clutch packs, all came off running machines: $10 per pack 16. Used but good Crank bearing w/seal: $20 17. Used but good Crank bearing w/o seal, 2 available: $15 each 18. Stock crank, comes with good bearings, gears and seals. Great shape. $120 21. Stock clutch basket and gear. Basket is blown out but gear is good. $15 (SALE PENDING) 22. Stock shift drum: $10 23. Axle locknut for durablue axle, nice. $10 24. Steering stem mount $10 25. Handle bar mounts: $8 26. Shift shaft, straight: $10 27. Air intake tubes, some guy swore by them and sent them to me with carbs. Never used them. $10 28. Front brake lines, complete from master cylinder to caliper. 3 available $15 each. 29. Front brake hard lines only: $10 30. Sprocket hub, PC blue: $20 32. Rear Brake hub PC blue, bolts are permanent to rotor: $15 34. Rear brake rotor, great shape: $15 35. Rear grab bar, stock, good shape: $20 36. Rear grab bar, modified, no fender mounts, has centered flag mount. PC silver vein, nice piece: $30 39. Water pump impellar, stock, new: $20 40. Stock clutch cover insert. 2 available, good shape: $8 each 43. Misc. lever, 2 available. $5 each 44. Stock timing plate: $8 45. Protaper bars, bottom tube is bent, fixable. Comes with pad and good grips: $30 shipped 46. Renthal bar pad, red: $10 shipped Let me know what you need, no reasonable offer refused. Thanks! Quote Link to comment Share on other sites More sharing options...
bc banshee Posted March 15, 2010 Report Share Posted March 15, 2010 How much for the air box? Quote Link to comment Share on other sites More sharing options...
87sheerips Posted March 15, 2010 Author Report Share Posted March 15, 2010 How much for the air box? $15 shipped. Comes with filter. Paypal: jdubswmu@yahoo.com Include description of item with payment. Thanks! Quote Link to comment Share on other sites More sharing options...
87sheerips Posted March 16, 2010 Author Report Share Posted March 16, 2010 Still Available as of 3/16!! 1. Trinity Stage IV Pipes, stainless, very nice, need cleaned and polished: $350 3. Front rim and tire: 21x7x10 One silver, one gold available: $40 each 5. Gas tank, fender bolts stuck in it, comes with petcock and cap: $20 6. Radiator hoses (3): $15 7. Gas tank plastics: Red, needs clips $20. Red with Graphic, one broken tab, needs clips $15 11. Stock head, great shape: $15 12. Stock rear brake lines, 4 available: $8 each. Will work for up to +4 swingarm. 13. Stainless rear brake line, up to +4 swingarm: $20 15. Useable used clutch packs, all came off running machines: $10 per pack 16. Used but good Crank bearing w/seal: $20 17. Used but good Crank bearing w/o seal, 2 available: $15 each 18. Stock stroke crank, comes with good bearings, gears and seals. Great shape. $120 21. Stock clutch basket and gear. Basket is blown out but gear is good. $15 (SALE PENDING) 22. Stock shift drum: $10 23. Axle locknut for durablue axle, nice. $10 24. Steering stem mount $10 25. Handle bar mounts: $8 26. Shift shaft, straight: $10 27. Intake Venturi tubes $10 28. Front brake lines, complete from master cylinder to caliper. 3 available $15 each. 29. Front brake hard lines only: $10 30. Sprocket hub, PC blue: $20 32. Rear Brake hub PC blue, bolts are permanent to rotor: $15 34. Rear brake rotor, great shape: $15 35. Rear grab bar, stock, good shape: $20 36. Rear grab bar, modified, no fender mounts, has centered flag mount. PC silver vein, nice piece: $30 39. Water pump impeller, stock, new: $20 40. Stock clutch cover insert. 2 available, good shape: $8 each 43. Misc. lever, 2 available. $5 each 44. Stock timing plate: $8 45. Protaper bars, bottom tube is bent, fixable. Comes with pad and good grips: $30 shipped 46. Renthal bar pad, red: $10 shipped Let me know what you need, no reasonable offer refused. Thanks! Quote Link to comment Share on other sites More sharing options...
bc banshee Posted March 16, 2010 Report Share Posted March 16, 2010 $15 shipped. Comes with filter. Paypal: jdubswmu@yahoo.com Include description of item with payment. Thanks! Still only $15 shipped to BC CANADA.Thank's John Quote Link to comment Share on other sites More sharing options...
87sheerips Posted March 16, 2010 Author Report Share Posted March 16, 2010 Still only $15 shipped to BC CANADA.Thank's John No, then I would be losing $10 $35 shipped. it will be $25 just to ship it easy. Thanks and let me know. Quote Link to comment Share on other sites More sharing options...
bc banshee Posted March 17, 2010 Report Share Posted March 17, 2010 No, then I would be losing $10 $35 shipped. it will be $25 just to ship it easy. Thanks and let me know. I sent you the $35 pay pal for the air box.Thank's john Quote Link to comment Share on other sites More sharing options...
87sheerips Posted March 18, 2010 Author Report Share Posted March 18, 2010 I sent you the $35 pay pal for the air box.Thank's john Got it, thanks! heres some pics, Ill have more soon 18. Stock crank, comes with good bearings, gears and seals. Great shape. $120 35. Rear grab bar, stock, good shape: $20 36. Rear grab bar, modified, no fender mounts, has centered flag mount. PC silver vein, nice piece: $30 22. Stock shift drum: $10 Quote Link to comment Share on other sites More sharing options...
87sheerips Posted March 19, 2010 Author Report Share Posted March 19, 2010 Stock disc brakes, front and rear. All 3 for $30 shipped Quote Link to comment Share on other sites More sharing options...
87sheerips Posted March 19, 2010 Author Report Share Posted March 19, 2010 Just sold: 11. Stock head, great shape: $15 18. Stock crank, comes with good bearings, gears and seals. Great shape. $120 27. Air intake tubes, some guy swore by them and sent them to me with carbs. Never used them. $10 Quote Link to comment Share on other sites More sharing options...
87sheerips Posted March 22, 2010 Author Report Share Posted March 22, 2010 BUMP... hit me up if you need ANYTHING! I will hook you up Quote Link to comment Share on other sites More sharing options...
