Tons of banshee parts
  • Replies 49
  • Created
  • Last Reply
Top Posters In This Topic
your posting somewhat confused me... do you have any stock size air intakes for stock carbs? the boots?
Sorry man, I will try and clean it up. It gets a little hairy with all these parts. yes I have intakes, PM me. $20 shipped for both.
STILL AVAILABLE as of 3/29/10:
1. Trinity Stage IV Pipes, stainless, very nice, need cleaned and polished: $350
3. Front rim and tire: 21x7x10 One silver, one gold available: $40 each
5. Gas tank, fender bolts stuck in it, comes with petcock and cap: $20
6. Radiator hoses (3): $15
7. Gas tank plastics: Red, needs clips $20. Red with Graphic, one broken tab, needs clips $15
8. Complete rear brake system w/stainless line up to +12” swinger. Fair pads. $8011. Stock head, great shape: $15
12. Stock rear brake lines, 4 available: $8 each. Will work for up to +4 swingarm.
13. Stainless rear brake line, up to +4 swingarm: $20
16. Used but good Crank bearing w/seal: $20
17. Used but good Crank bearing w/o seal, 2 available: $15 each
22. Stock shift drum: $10
23. Axle locknut for durablue axle, nice. $10
24. Steering stem mount $10
25. Handle bar mounts: $8
26. Shift shaft, straight: $10
28. Front brake lines, complete from master cylinder to caliper. 3 available $15 each.
29. Front brake hard lines only: $10
30. Sprocket hub, PC blue: $20
35. Rear grab bar, stock, good shape: $20
36. Rear grab bar, modified, no fender mounts, has centered flag mount. PC silver vein, nice piece: $30
39. Water pump impellar, stock, new: $20
40. Stock clutch cover insert. 2 available, good shape: $8 each
43. Misc. lever, 2 available. $5 each
44. Stock timing plate: $8
45. Protaper bars, bottom tube is bent, fixable. Comes with pad and good grips: $30 shipped
46. Renthal bar pad, red: $10 shipped
  • 2 weeks later...
