Tons of banshee parts
Spring is here and its time to get rid of the inventory. I have a lot of stuff up for grabs here. Detailed pics can be provided if needed.
All prices listed are shipped including paypal fees. Overseas, add $20 for shipping to these prices.
Paypal jdubswmu@yahoo.com
Please PM me with the listed item number, as well as in paypal.
Thanks!!
Banshee parts for sale 3/7/10 (Nerf bars sold locally right after I took this pic)
1. Trinity Stage IV Pipes, stainless, very nice, need cleaned and polished: $350
2. Paul Turner High Rev pipes, new high temp paint, nice pipes: $200
3. Front rim and tire: 21x7x10 One silver, one gold available: $40 each
4. Front rims (pair): 7x10 Gold, $40 for the pair
5. Gas tank, fender bolts stuck in it, comes with petcock and cap: $20
6. Radiator hoses (3): $15
7. Gas tank plastics: Red, needs clips $20. Red with Graphic, one broken tab, needs clips $15
8. Complete rear brake system w/stainless line up to +12” swinger. Fair pads. $80
9. Complete rear brake system w/stock line, blockoff plate & brake pedal. Good pads. $50
10. Rear brake caliper w/stock line, no pads. $20
11. Stock head, great shape: $15
12. Stock rear brake lines, 4 available: $8 each. Will work for up to +4 swingarm.
13. Stainless rear brake line, up to +4 swingarm: $20
14. Hinson Billet cutch basket, has damage and bolts broke off. Could be fixed? $10
15. Useable used clutch packs, all came off running machines: $10 per pack
16. Used but good Crank bearing w/seal: $20
17. Used but good Crank bearing w/o seal, 2 available: $15 each
18. Stock crank, comes with good bearings, gears and seals. Great shape. $120
19. Wiseco pistons, bore measured 63.25” ( I think they were .020” over so whatever that is lol) good shape, come with rings, pins, clips and good wrist pin bearings. $30
20. A-arm inner shaft: $8
21. Stock clutch basket and gear. Basket is blown out but gear is good. $15
22. Stock shift drum: $10
23. Axle locknuts: 1 for stock axle, could be polished up nice, has some gouges from wrench. $10
i. 1 for durablue axle, nice. $10
24. Steering stem mount $10
25. Handle bar mounts: $8
26. Shift shaft, straight: $10
27. Air intake tubes, some guy swore by them and sent them to me with carbs. Never used them. $10
28. Front brake lines, complete from master cylinder to caliper. 3 available $15 each.
29. Front brake hard lines only: $10
30. Sprocket hub, PC blue: $20
31. Rear wheel hubs PC blue $30 for pair
32. Rear Brake hub PC blue, bolts are permanent to rotor: $15
33. Rear Brake hub, raw, with rotor, useable: $10
34. Rear brake rotor, great shape: $15
35. Rear grab bar, stock, good shape: $20
36. Rear grab bar, modified, no fender mounts, has centered flag mount. PC silver vein, nice piece: $30
37. Stock foot pegs: $20
38. Amp Link, aftermarket chain roller: $25
39. Water pump impellar, stock, new: $20
40. Stock clutch insert. 2 available, good shape: $8 each
41. Clutch perch, with quick adjust: $15 shipped
42. Front Brake master cylinder, bad shape but do work with good levers, 2 available. $10 each
43. Misc. lever, 2 available. $5 each
44. Stock timing plate: $8
45. Protaper bars, bottom tube is bent, fixable. Comes with pad and good grips: $30 shipped
46. Renthal bar pad, red: $10 shipped
  • Replies 49
  • Created
  • Last Reply
Top Posters In This Topic
Thanks!!
Pm sent
Edited by troyzstang
Items SOLD:
Thanks guys, and remember everything is OBO. I just need this stuff out of my shop. :cheers:
Items SOLD:
THANKS!
