melon350 Posted March 6, 2010 Report Share Posted March 6, 2010 Not sure what to do with these, installing different intake manifolds and new vf3's. The reeds have a raised section and the manifolds are flat. It doesn't seem like the gaskets that came with them will seal at all, they just catch the edge of the raised part and are the same thickness. I was thinking if I cut my own and made them come all the way in with a hole in the middle close to the center hole they would seal up. Any thoughts or suggestions? What are thoughts on reed spacers, had some on there before, keep em or lose them? Quote Link to comment Share on other sites More sharing options...
smokin 421 Posted March 6, 2010 Report Share Posted March 6, 2010 just my .02 i always seal them up with silicone along with the gaskets that way ur sure not to have any problems just dont get it to caked on that it squeezes into the intakes or reed cages... Quote Link to comment Share on other sites More sharing options...
melon350 Posted March 6, 2010 Author Report Share Posted March 6, 2010 I usually use a thin film of rtv on them as well. Quote Link to comment Share on other sites More sharing options...
firebanshee Posted March 7, 2010 Report Share Posted March 7, 2010 I removed the raised section on my Vforce 2s. Quote Link to comment Share on other sites More sharing options...
melon350 Posted March 7, 2010 Author Report Share Posted March 7, 2010 I was thinking earlier how nice it would be if that wasn't there. How did you do it? Would it effect using them with other intakes in the future? Quote Link to comment Share on other sites More sharing options...
firebanshee Posted March 7, 2010 Report Share Posted March 7, 2010 I was thinking earlier how nice it would be if that wasn't there. How did you do it? Would it effect using them with other intakes in the future? I took it off with a die grinder and a sanding wheel. A dremel would work. I have not had any problem since i did it, i am glad i did it. I have not seen an advantage to have the raised part but if there is i am sure someone will chime in. Quote Link to comment Share on other sites More sharing options...
BigMatt Posted March 7, 2010 Report Share Posted March 7, 2010 ya... I wanted to know about reed spacer as well, do they do anything or just another boost bottle? also do you have to re-jett when you put them in and whats the best thickness to get? Quote Link to comment Share on other sites More sharing options...
firebanshee Posted March 7, 2010 Report Share Posted March 7, 2010 ya... I wanted to know about reed spacer as well, do they do anything or just another boost bottle? also do you have to re-jett when you put them in and whats the best thickness to get? The only thing i have ever used a reed spacer for it to get my float bowl of my clutch arm. I don't think you get any performance gain from them. Quote Link to comment Share on other sites More sharing options...
