4mm FAST motor
4mm FAST motor for sale, mods include:
4mil dune ported cylinders by FAST Racing
4mm longrod hotrods crank with extra weld and Maxload bearing
Cases are ported by FAST. They have the usual chain whack.
FAST clutch with new inner and outer hubs
Hinson billet basket
Boss billet intake for 33-35mm carbs with built in crossover.
Shift shaft mod and cascade shift star
Noss coolhead with 19cc domes cut for the 4mil crank. Squish is .44 and PSI is 175
Adjustable timing plate
Stock stator and stock flywheel, both in good shape.
Transmission is stock and in great shape.
All the old worn out bolts, nuts, washers and bearings were replaced during this build as well.
This motor was built at the end of last season and has low hours on it. It is a very hard running motor that has lots of torque to ride trails. I will sell it with or without 35mm pwk airstrikers and K&N pods. 2100+ shipping with carbs and 1800+shipping without carbs. Bolt this motor in and go! I will get pics as soon as possible.
Will this run with a stock 4 mil cub?
Good Question... How does it hold up to a 421, non drag ported cub on race fuel.... I've heard of some people running dune/drag ported, 4mills,
that run with or will out run, a 421 unported cub.... just curious, theres got to be some guys looking at this that should know... I havent got to
drag race my 421cub yet, so yeah, id like to know......
IF the bike was setup correctly these cyls will easily hang with 4mm cubs. It all depends on setup guys.
This motor not even setup right was walkin on my Raptor and i promise you, that is NO easy task as my Rappy has also beatin 4mm cubs!!
