Ball Joint Questions
Beerplease
I have a stock 2001 Banshee and I am in the process if replacing all the worn out pieces on the bike. One of the lower front control arm ball joints has a bent shaft and a torn up boot. Is it possible to get replacement stock-type ball joints? And if so do the old ones just press out of the a arms. And If not where can I get a set of boots to replace the torn one until I can find some used arms?
No, the stock ball joints are welded into the arm and the only way to replace the ball joint is to replace the whole arm, assuming that they are stock arms. That is why aftermarket arms are so popular, you can buy a set of aftermarket a arms for about the same money as a complete set of stockers and then in the future you can replace just the ball joints.
  • 2 weeks later...
