LARGER PRIMARY GEAR. ANY OF YOU USING THEM?
blowit
what you got up your sleeve brandon?
We were discussing making some small changes to our water pump gears to work with the larger PTO gears without having to cut them up. Problem is there is a few different ratios being used and we will have to watch our gear structure so we do not have any adverse affects. I doubt it will be an issue but we should probably do some FEA of a new design and see how it looks structurally.
Going to have to get some gear diameters so I can determine how much we can trim.
Brandon
Brandon
are you talking about making a different ratio water pump gear for the crank and whats on the water pump? the primary gears for the crank to clutch dont really make that much of a difference on those.
I think what he is trying to say is that on the 2.36's the gear on the crank is so larger that it rubs part of the water pump gear and a little tweaking is required. I am assuming that Brandon is going to try and redesign so that the buyer/assembler doesn't have to do a field mod, it would just be a drop in.
Yep.. Thats what I think he's workin on. I use the 2.68's and I had to do a bit of grinding on the washer.. Nothing big.. but it was a pain in the ass since I was in a hurry to get it together last minute.. lol
