blaster2006 Posted February 24, 2010 Report Share Posted February 24, 2010 Hey! i really need you guys help! I am trying to remove the chain on my banshee and i found out it does not have a lock? so there is no way i can remove it... i tried many ways and its not coming off... thats really stupid how stock chains dont have a friggin lock... I need to replace it and can't get it out. Reason why i need to replace: because its way too loose and i already extended the swingarm to its max and its still way too loose.. i've had this chain for 4 years now so it needs a change... but i need help on any suggestions on how to get it out.. my friend said he is going to get a grinder and grind it off.. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 24, 2010 Report Share Posted February 24, 2010 take a grinder and grind off the rivets off one side of a link. then take a hammer and screwdriver and drive off side of the link that you ground the rivets from. Quote Link to comment Share on other sites More sharing options...
00sheerzr Posted February 24, 2010 Report Share Posted February 24, 2010 grab a die grinder, a 6inch cutoff wheel and some safety glasses and your problem is solved, or you could use a chain breaker Quote Link to comment Share on other sites More sharing options...
donkeypuncher Posted February 24, 2010 Report Share Posted February 24, 2010 since you've tightened your chain as much as possible and its still loose have you tried loosening it as much as you can to see if it has enough slack to just pull off? Quote Link to comment Share on other sites More sharing options...
blaster2006 Posted February 24, 2010 Author Report Share Posted February 24, 2010 it slides off the back sprocket ( it dislocates)... it can come off from the top of the back sprocket.. but then from the bottom where there is that plastic white thing that holds it under the back sprocket it gets stuck over there Quote Link to comment Share on other sites More sharing options...
blaster2006 Posted February 24, 2010 Author Report Share Posted February 24, 2010 nevermind, we got it off with a hammer and chisel Quote Link to comment Share on other sites More sharing options...
FrankieSquid Posted February 24, 2010 Report Share Posted February 24, 2010 nevermind, we got it off with a hammer and chisel Yes a BFH sometime does the trick Quote Link to comment Share on other sites More sharing options...
Whyzedtwofiveoh Posted February 24, 2010 Report Share Posted February 24, 2010 Bolt cutters. Quote Link to comment Share on other sites More sharing options...
papa_smurf49319 Posted February 25, 2010 Report Share Posted February 25, 2010 The stock chains dont have a master link? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 25, 2010 Report Share Posted February 25, 2010 Sure the clip isn't on the inside of the chain? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted February 25, 2010 Report Share Posted February 25, 2010 The stock chains dont have a master link? I bought 2 Banshees brand new from a dealer and a third one that was new enough to have a stock chain and they all had a master link on them, also my kid's Blaster was bought brand new and had a master link. Most, if not all Yamaha sport quads come with a DID o-ring chain and all of them have a master link that I know of. The chains without master links are usually used on street bikes or are aftermarket. Quote Link to comment Share on other sites More sharing options...
