Alex29573 Posted February 23, 2010 Report Share Posted February 23, 2010 can anyone please tell me if these will work and what do i do with the nipple coming out of the bottom of the float bowl? also, what about the other nipple i put an arrow on? and where i put in the fuel hose from the gas tank, does it matter that these carbs have the nipple facing down? Quote Link to comment Share on other sites More sharing options...
Alex29573 Posted February 23, 2010 Author Report Share Posted February 23, 2010 second pic showing the fuel inlet that faces downwards Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted February 23, 2010 Report Share Posted February 23, 2010 Is this for a single carb set up? Or for a stroker motor? Quote Link to comment Share on other sites More sharing options...
Alex29573 Posted February 23, 2010 Author Report Share Posted February 23, 2010 it would be 2 of these carbs on a 421 stroker cub i was running TM28mm carbs on the motor and then playing around tried out my brother's 35mm TMX carbs and the difference was HUGE. just revving in idle you can tell a difference. I'm looking into 39mm PWK because that is what the builder told me to get. Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted February 23, 2010 Report Share Posted February 23, 2010 Well then I dont see why they wouldnt work. I have been trying to find some 30mm carbs off of a sled for some time. But living in Phx doesnt help me one bit. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted February 23, 2010 Report Share Posted February 23, 2010 They are prolly a pumper carb w/the inlets turned down. I am not sure what the nipples are w/o having the carbs in front of me. Quote Link to comment Share on other sites More sharing options...
Alex29573 Posted February 23, 2010 Author Report Share Posted February 23, 2010 if they are pumper carbs, would they have floats inside? these have floats. thanks everyone for the replies! Quote Link to comment Share on other sites More sharing options...
Blewbyu Posted February 23, 2010 Report Share Posted February 23, 2010 Those are defenetely pumper carbs, you would have to buy a pump and put a pulse line in your cylinder, but they will work on your bike. just cap off that other vent on the side and buy the nuts that come on the 39pwk gravity fed bowls and replace those with the ones on your bowls. Obviously you will have to jet accordingly... Quote Link to comment Share on other sites More sharing options...
Alex29573 Posted February 23, 2010 Author Report Share Posted February 23, 2010 (edited) thanks man, i think i will just look for a regular set of gravity fed PWKs!! how can i tell if they are pumper or gravity fed carbs? Edited February 23, 2010 by Alex29573 Quote Link to comment Share on other sites More sharing options...
J-Madd Posted February 23, 2010 Report Share Posted February 23, 2010 thanks man, i think i will just look for a regular set of gravity fed PWKs!! how can i tell if they are pumper or gravity fed carbs? By re-reading Blewbyu's post j/k. THe fuel inlets are pointed down on the pumpers. You'll also need to put some chokes in those. Quote Link to comment Share on other sites More sharing options...
Alex29573 Posted February 23, 2010 Author Report Share Posted February 23, 2010 ok cool thanks Quote Link to comment Share on other sites More sharing options...
sheefreak Posted February 23, 2010 Report Share Posted February 23, 2010 There are also pumper carbs that have the inlets facing up. You can tell the difference by the size of the fuel inlet. I am not sure what the sizes are but the inlets on pumper carbs are smaller than gravity fed. Quote Link to comment Share on other sites More sharing options...
superfastyfz450driver Posted February 24, 2010 Report Share Posted February 24, 2010 snowmobile carbs use a very small neede and seat set up like on a mikuni tmx set up for a sped will use a size 1.5 needle and seat but for gravity feed your going to need a size 3.5 in my oppinion if the inlet port for the fuel line was angled down or up for gravity feed wouldnt make a difference it was probably done like that to route the fuel lines on the sled properly, th nipple on the bottom of the float bowls is for whats called a water trap on most sleds they use a chunk of 3/8ths clear hose roughly 2-3 inchs long with a plug in the end , what this does is since water is heavier then fuel it will get trapped in there rather then lay in the bowl, periodically you should drain them to make sure everything is ok Quote Link to comment Share on other sites More sharing options...
Alex29573 Posted February 25, 2010 Author Report Share Posted February 25, 2010 can you run a pump fed carb by gravity?? i understand you probably cant run a gravity fed carb with a pump because that type of carb is not set up for any pressure. but how about vice versa? Quote Link to comment Share on other sites More sharing options...
sheefreak Posted February 25, 2010 Report Share Posted February 25, 2010 You definately cannot run a pump fed carb w/o pump on alky, and I don't think I would chance it on gas either. The opening is so small it will not fill the bowls fast enough when you are running wide open. A pump is not hard to setup and a mikuni pump is like $60 new. Quote Link to comment Share on other sites More sharing options...
