case to cylinder mis match
cbn70
Hi,
I am currently rebuilding a 96 shee. I am putting the engine back together and noticed a mis match between the top cases and the cylinder. Is this normal. Can it be fixed. is it something to worry about. Will I get more power if I match the top case to the cylinder. thanks
Your refering to the side transfer ports right? Yea you can match that up. That is what is usually refered to as case porting, and is worth a couple of hp on a ported banshee. Be carefull on the flywheel side. It is kind of thin and you can grind a hole right through the cases.
Well looks like I know what I will be doing tonight. Wish me luck. Hope I don`t make a hole. hahaha. Any one have any pics Hope that I notice a difference in it. Will just be a stock motor, but would be nice to have more. Especially since this will be free power. gotta like that.
Here is loco's port matched cases that fast done. I didnt go out that far. I just went out a little ways then tapered the top out farther to match the cylinder.
You dont want to opean them up to far and make them larger / wider than the cylinder. That will cause the opposite affect where the cylinder is narrower than the top case. That will cause a flat lip to protrude out and is wose for performance than having the cylinders wider than the top case. The air flowing up to the cylinders will catch the flat lip and cause turbulance.
Also make sure to use the dowles to locate the gasket on the cylinders for trimming. Then use the dowls on the case half to locate the gaskets for marking.
