Pancake bearing Install Curious if this is right.
01banch
I apologize in advance for the 37 questions I have asked during the build of my motor. But just like the money I spent on the parts I would prefer not to cut any corners sooo.... The pancake bearing I have seems to stick out and the nut does not fall into hte outer clutch Hub I am curious if that is how it's supposed to be. Also I have the outer hub sitting against a washer which sits against the bearing which sits against the other washer then the rest of the assembly. Is this the correct oreder the pieces should go? I have apicture to show you question number one. and can get a picture to number 2 if need be.
THAT LOOKS WRONG TO ME.I JUST DID MINE TODAY.THE PANCAKE BEARING PART GOES ON THE INSIDE OF THE PRESSURE PLATE.THE END WITH THE MACHINED FLATS GOES THROUGH THE PRESSURE PLATE.THEN YOU ADJUST IT USING A PHILLIPS SCREW DRIVER OR ALLEN WRENCH(depending on brand) AND THEN LOCK IT IN PLACE WITH THE NUT AND YOUR DONE.
