spark plugs coming loose
Alex29573
I've been there, find the problem.....It was very expensive when i decided not too...I'd definitly back the timing down a bit...your motor is telling you something is wrong...
Can someone tell me if when sparkplugs get loose - if its a problem with not enough octane or is it a problem with too lean of a jet?
thanks
locktite ur spark plugs... :rotflmao: ..check it out before a $2.50 spark plug causes some major damage.. x2 on the domes and timing. bring it down brotha...
7 d is too much on a gas motor. put it to 4 and leave it alone..
the domes in a cub have to be over .40-.45 tho squish clearance, might even have domes for a different angle in there AKA blaster piston on banshee angle dome..
you MAY have poped an o-ring on the compression side and its leaking coolant in to the cylinders,, doubtfull but its the result of deto, timing, octaine, bad dome match, air leak etc etc on cubs.
sunoco says that gas is good up to 13:1 compression but im thinking i might need something rated for more compression since im mixing the fuel with oil...
can anyone help????
well, that's up to 13:1 and based on a 4stroke aplication, which this is not
x2, you definately should know the squish clearance and band/angle. going a little more conservative can solve deto problems, and mabey a little sacrifice that you wouldn't notice. I push the octane limits pretty far by running all the way up @ .052" clearance. also, what range is it set for? topend power? mid-top? perhaps, you don't need so much compression or timing. it could yeild better by turning it down, but that's what was suggested for a reason.
Group:
Members Posts:
111 Joined:
28-July 09 Posted 14 February 2010 - 03:06 PM
yes im tightening them hard enough...
im runninig an uncorrected 12:1 compression ratio with 7 degree timing advance.
i run sunocco 110
that gas is leaded/unoxygenated and 105 MON, 110 (r+m)/2
well, then that is not really "110" by the math. perhaps that is a problem.
also, make sure you do not over-tighten the plugs when you put them in. if you over compress the ealing ring, it can just streatch the treads out when it heats up. follow the directions of the plug-i think only 5/8 turn after it hits the seal ring
NOT necessarily! I sent my whole motor to Jeff at FAST and thats what he set my timing on my 4mill at +7. Ive been running c12 but Im switching over 2 Sunoco 110, got a 5 gl jug full now, havent ran any yet to tell if thats the guys prob or not.
Throw that plug lock away. IMO. To answer the other part of your question lean jetting can absolutely cause detonation. I know guys that run their bikes kinda rich and run 7 degrees all day but on a gas motor jetted perfect 7deg is usually too much to run more than one or two hard passes. if your burn ring on your plug is .080 tall then you are jetted plenty rich to run 4 to 5 degrees. You should probably keep an eye on your water temps I'd bet its detonating once hot.
I had my sparkplugs come loose when riding. For me it was just a vibration issue nothing else. I remember seeing a billet bracket type of thing where it hold both the sparkplugs in place preventing it from coming loose i just dont remember where. I just forgot to tighten them really good. This is if you not having mechanical issues.
